ONTAP Hardware
Volume delete script
Spin1phd
All,
I am building scripts to run against my filers.
After migrations I am looking to build a script that will destroy the volumes.  I use the following to offline them and per processes then destroy them 24hrs later.
                       for i in 'cat /home/user/file.txt'; do ssh filer vol offline $i; done
Now I have this so far but when destroying the volume confirmation to destroy is asked for each volume.  is there a setting to turn that off.  the Filers are 7-mode.
                       for i in 'cat /home/user/file.txt'; do ssh filer vol destroy $i; done
1 REPLY 1
sgrant
Hello,
You can use the "-f" flag to destroy a volume without prompting.
Hope you find it useful.
Cheers,
Grant.
