ONTAP Hardware
What is the maximum volume size supported on ISCSI Lun on Netapp 8200?
ashrafbinali
Dear All,
What is the maximum volume size supported on ISCSI Lun on Netapp 8200 (VMWARE)?
1 ACCEPTED SOLUTION
jcolonfzenpr
Hi,
  • Maximun Aggr size: 400TB
  • Maximun Flexvol size 100TB
  • Maximun Lun size: 16TB
Hope this help.
Good luck!
Jonathan Colón | Blog | Linkedin
5 REPLIES 5
jcolonfzenpr
Hi,
Hope this help.
Good luck!
ashrafbinali
is there Different LUN Size(FC,FCOE and ISCSI),
That screenshot is not cleared, please share downloadable PDF.
mrahul
16 TB max lun size is same across all protocols. No difference.
paul_stejskal
FC/iSCSI are just connections. That doesn't impact the way the system works outside of the connectivity.
andris
These types of "limits" questions can usually be answered by looking up the platform and ONTAP version in the NetApp Hardware Universe.
https://hwu.netapp.com
