ONTAP Hardware
can not create the aggregate
Cesarsm86
the error: can not create the aggregate because the syncmirrow pool does not cointain sufficient spare disk with a maching disk RPM
I am configuring a new FAS2720 (2set) with ONTAP 9.6
One is a total of 8 x 2 TB of HDD units, and the other is 4 x 960 GB of SSD.
The internal drives were already partitioned with advance disk partitioning with raid-dp in the HDD drives, giving me 2 partitions of 4 disks as root.
I have a problem to create my aggregate for data in my controllers, the 4 SSD disks are free.
how else can I configure my computer, in order to create my aggregates for data
4 REPLIES 4
Masters
You need ask your boss yorch or Jaír the chicken boy
Cesarsm86
it's cosmetic
SpindleNinja
you will need to create 1 data aggr from the SATA and then add the SSD as a Flash Pool/Storage Pool to the SATA aggr.
andris
+1.
With the limited number of drives involved, you're probably looking at an active/passive configuration to maximize the amount of available storage.
See:
http://docs.netapp.com/ontap-9/topic/com.netapp.doc.dot-cm-psmg/GUID-4AC35094-4077-4F1E-8D6E-82BF111354B0.html
