ONTAP Hardware
difference between netapp E series & FAS series
saranraj456
Hello friends,
What is the significant difference between netapp E series & FAS series ?
Also , what is the Prime reason for going to e-series ? . i used to see its mostly used for data intensive workloads, but it didn't see any much alterations in the hardware config of both systems.
Thanks,
Saran
1 ACCEPTED SOLUTION
saranraj456
Core architecture and purpose was different for e -series
1 REPLY 1
saranraj456
