ONTAP Hardware
fas 270 igroup problem
CLUSTERMAGNET
Guys,
  Setting up a NetApp Fas270.  Previous owners had 2 heads in the cluster.  Now this NetApp is a standalone device.
  I think the problem I am having, is I need to tell NetApp that its a standalone box.
  Any changes that I am trying to make, ie , add fc initiator groups, etc, give me warnings such as:
  (mapping)  lun map: Cluster partner could not be reached.
  Can someone pleaes help me with this issue?  I am trying to map some fc shelves to vshere 4.1
Thanks!!!
1 REPLY 1
daehnrich_bsh
Hello, you removed the cluster licenses?
and at the halt promt CFE> you have to use set_env or "set-env default" that he forget the cluster ID. After this it should be possible to use the System as stand alone.
Contact me when you have Problems.
cheers Soeren
