ONTAP Hardware
fcp start: Partner WWNN must match local WWNN to start FCP
KCOKYAMAN
When i try to start FCP service get a following error message...
MC-Netapp-A> fcp start
I checked Partner but match with local nodename...
MC-Netapp-A> cf partner
MC-Netapp-B
MC-Netapp-A> fcp nodename
Fibre Channel nodename: 50:0a:09:80:88:e3:c6:01 (500a098088e3c601),
MC-Netapp-B> fcp nodename
MC-Netapp-A> version
NetApp Release 8.2.1RC1 7-Mode: Wed Nov 20 15:25:04 PST 2013
My storage is FAS3220... What is the problem? Any idea?
1 ACCEPTED SOLUTION
KCOKYAMAN
Solved... This is interconnect problem. When fix interconnect connections FCP started.
3 REPLIES 3
radek_kubka
This is odd. Can you try changing WWNN on both nodes to a new value & see what happens then?
> priv set diag
> fcp set nodename 50:0a:09:80:88:e3:c6:02
> priv set
KCOKYAMAN
yes... I tried set nodename with same wwnn. nothing has changed.
KCOKYAMAN
