ONTAP Hardware
how to add lun array of 3rd party
Eswar
Hi Experts,
I'm new to netapp and I would like to know how to add lun array.
In our  Company , We are using V series - V3140 filer ,  Ontap 8.2 , Aggr 64 Bit.
BR,
Eswar
5 REPLIES 5
RPHELANIN
To begin with you need a FlexArray license
Eswar
Thanks for the response.
Once we have the license , How to add a lun array to Hosts?
Which is same a normal lun assignment ?
For example:
pri> vol create vol1 aggr1 10g
pri> vol status
pri> ping <windows ip address>
pri> lun create -s 7g -t windows /vol/vol1/newlun
pri> lun show
pri> igroup create -i -t windows igroup_name iqn.1991-05.com.microsoft:chennai
pri> igroup status
pri> lun map /vol/vol1/newlun igroup_name
ALso , How to identify lun array(3rd party ..like emc , hitachi .....) over general luns.
Is there any commands to distinguish
Thanks & Regards,
Eswar
RPHELANIN
Have you had a look at the FlexArray Implementation Guide?
https://library.netapp.com/ecm/ecm_download_file/ECMP1369079
Eswar
Thanks for the link  Smiley Wink , I got some of the information.
Coming to my other question  , In sysconfig -a /sysconfig -r outputs you will get mixed outputs , where as i want to distinguish genral luns (From disks in shelfs ) & lun arrays , I just want to know whether it is possible to distinguish luns from ( disk shelf) as one outputs and lun arrys(EMC , HItachi ,HP XP IBM XP) as other output , It would be helpful in while adding disks in lun array.
Thanks in Advance,
Eswar
RPHELANIN
sysconfig -a / -r will not give you any LUN information, sysconfig -r will give you aggregate / RAID / disk info. When you add in the frreign disks, create an aggregate for those disks, then a volume(s) and then your Lun(s)
