ONTAP Hardware
how to reassign disks
CCOLEMAN_
Hello,
I have added a DS4243 with 24 1TB drives to my FAS2040.
It looks like the disks on my new shelf have already been assigned before. Anytime I try to do a disk_removeownership or disk_unassign it says this can only be done in maintenance mode?
How can I unassign and reassign the disks with out taking the filer down? (I only have one controller)
Thanks!
1 ACCEPTED SOLUTION
RodrigoNascimento
Hello,
Try this:
Identify the actual sysid owner:
> disk show
Remove the ownership using disk assign:
> disk assign <disk_id> -o unowned -s <sysid>
Regards,
Nascimento
NetApp - Enjoy it!
27 REPLIES 27
RodrigoNascimento
Hello,
Try this:
> disk show
Regards,
Nascimento
NetApp - Enjoy it!
CCOLEMAN_
Hey Rodrigo,
When I do a "disk show" it only shows me the internal disks in my 2040 with.
But heres what I get anyway,
netapp01*> Tue Dec 20 15:52:23 GMT [netapp01:diskown.RescanMessageFailed:warning        ]: Could not send rescan message to unowned. Please type disk show on the consol        e of unowned for it to scan the newly inserted disks.
Tue Dec 20 15:52:23 GMT [netapp01:diskown.RescanFailureReasonHttpd:warning]: The        rescan failure is likely due to the httpd.admin.enable option being off.
Tue Dec 20 15:52:23 GMT [netapp01:sfu.firmwareUpToDate:info]: Firmware is up-to-        date on all disk shelves.
RodrigoNascimento
And what is the output for 'disk show -n' ?
CCOLEMAN_
netapp01> disk show -n
disk show: No disks match option -n.
netapp01>
CCOLEMAN_
Not sure if this helps but this is what I get for remove_ownership
netapp01*> disk remove_ownership 0d.01.19
disk remove_ownership: Disk 0d.01.19 is not owned by this node.
RodrigoNascimento
'disk show -v'
It shows all disks attached to the controllers.
-n shows unowned and -a shows all assigned....
Please, put here the 'disk show -v' output.
CCOLEMAN_
DISK       OWNER                      POOL   SERIAL NUMBER         HOME
0c.00.8      netapp01  (135084092)    Pool0  9QJ755P7              netapp01  (135084092)
0c.00.4      netapp01  (135084092)    Pool0  9QJ754VJ              netapp01  (135084092)
0c.00.1      netapp01  (135084092)    Pool0  9QJ758CC              netapp01  (135084092)
0c.00.0      netapp01  (135084092)    Pool0  9QJ755EE              netapp01  (135084092)
0c.00.2      netapp01  (135084092)    Pool0  9QJ75580              netapp01  (135084092)
0c.00.6      netapp01  (135084092)    Pool0  9QJ755HD              netapp01  (135084092)
0c.00.3      netapp01  (135084092)    Pool0  9QJ7550Z              netapp01  (135084092)
0c.00.9      netapp01  (135084092)    Pool0  9QJ755C8              netapp01  (135084092)
0c.00.11     netapp01  (135084092)    Pool0  9QJ754PJ              netapp01  (135084092)
0c.00.10     netapp01  (135084092)    Pool0  9QJ754Y4              netapp01  (135084092)
0c.00.7      netapp01  (135084092)    Pool0  9QJ755BV              netapp01  (135084092)
0c.00.5      netapp01  (135084092)    Pool0  9QJ7594Z              netapp01  (135084092)
0d.01.2      drfas2040 (135064522)    Pool0  WD-WCAW30897168       drfas2040 (135064522)
0d.01.4      drfas2040 (135064522)    Pool0  WD-WCAW30895989       drfas2040 (135064522)
0d.01.9      drfas2040 (135064522)    Pool0  WD-WCAW30897508       drfas2040 (135064522)
0d.01.19     drfas2040 (135064522)    Pool0  WD-WCAW30897956       drfas2040 (135064522)
0d.01.13     drfas2040 (135064522)    Pool0  WD-WCAW30896086       drfas2040 (135064522)
0d.01.15     drfas2040 (135064522)    Pool0  WD-WCAW30888554       drfas2040 (135064522)
0d.01.6      drfas2040 (135064522)    Pool0  WD-WCAW30897141       drfas2040 (135064522)
0d.01.1      drfas2040 (135064522)    Pool0  WD-WCAW30888541       drfas2040 (135064522)
0d.01.10     drfas2040 (135064522)    Pool0  WD-WCAW30891208       drfas2040 (135064522)
0d.01.7      drfas2040 (135064522)    Pool0  WD-WCAW30895985       drfas2040 (135064522)
0d.01.5      drfas2040 (135064522)    Pool0  WD-WCAW30891439       drfas2040 (135064522)
0d.01.11     drfas2040 (135064522)    Pool0  WD-WCAW30896477       drfas2040 (135064522)
0d.01.0      drfas2040 (135064522)    Pool0  WD-WCAW30896481       drfas2040 (135064522)
0d.01.23     drfas2040 (135064522)    Pool0  WD-WCAW30865750       drfas2040 (135064522)
0d.01.21     drfas2040 (135064522)    Pool0  WD-WCAW30875507       drfas2040 (135064522)
0d.01.12     drfas2040 (135064522)    Pool0  WD-WCAW30888529       drfas2040 (135064522)
0d.01.18     drfas2040 (135064522)    Pool0  WD-WCAW30897930       drfas2040 (135064522)
0d.01.20     drfas2040 (135064522)    Pool0  WD-WCAW30865773       drfas2040 (135064522)
0d.01.22     drfas2040 (135064522)    Pool0  WD-WCAW30876127       drfas2040 (135064522)
0d.01.14     drfas2040 (135064522)    Pool0  WD-WCAW30902526       drfas2040 (135064522)
0d.01.8      drfas2040 (135064522)    Pool0  WD-WCAW30895502       drfas2040 (135064522)
0d.01.3      drfas2040 (135064522)    Pool0  WD-WCAW30890577       drfas2040 (135064522)
0d.01.16     drfas2040 (135064522)    Pool0  WD-WCAW30897939       drfas2040 (135064522)
0d.01.17     drfas2040 (135064522)    Pool0  WD-WCAW30891044       drfas2040 (135064522)
drfas2040 is the old controller it was on
RodrigoNascimento
try:
disk assign 0d.01.17 -o unown -s 135064522
CCOLEMAN_
netapp01*> Tue Dec 20 16:33:20 GMT [netapp01:diskown.RescanMessageFailed:warning]: Could not send rescan message to unowned. Please type disk show on the console of unowned for it to scan the newly inserted disks.
Tue Dec 20 16:33:20 GMT [netapp01:diskown.RescanFailureReasonHttpd:warning]: The rescan failure is likely due to the httpd.admin.enable option being off.
Tue Dec 20 16:33:20 GMT [netapp01:sfu.firmwareUpToDate:info]: Firmware is up-to-date on all disk shelves.
RodrigoNascimento
are you in 'priv set diag' mode?
and it is: '-o unowned', sorry for the typo mistake.
CCOLEMAN_
i'm in 'priv set advanced'
RodrigoNascimento
have you tried with '-o unowned' and it not work?
aborzenkov
it is
disk assign 0d.01.17 -s unowned
possibly also add "-f" for "force"
RodrigoNascimento
Yes, it is!
Thanks Aborzenkov... -s unowned and not -o unowned.
fletch2007
In 8.1.2 this works:
disk assign 6b.71 -s unowned -f
ref: https://kb.netapp.com/index?page=content&id=1010853&actp=LIST_POPULAR
cheers!
CCOLEMAN_
adding -f worked!!!!
Just curious, why does it require -f? that just seems a little scary
RodrigoNascimento
Sorry for the confusion with the options....
Good to know it solves your problem.
See you!
Nascimento
NetApp - Enjoy it!
abdul_wahab
Hi,
"The -f option will be use if disk is not owned by the local node and may result in data corruption if the current owner of the disk is up".
I assume in your case you use the disk shelf from another system which is completely separate from the system on which you are working.
And thanks Nascimento. Your solution also solve my problem.
Abdul Wahab
rmontavonsa
Hello,
i have changing a disk on one of my controller (fas2040) but i can't assign the new disk of spare to the pool1.
i try this command "disk assign 0d.01.5 -s unowned -f". This command work without error. When i make a "disk show -n" i see the disk.
But when i try to assign the disk to the pool1 (they are 3 disks of spare on spool0) with this command: "disk assign 0d.01.5 -p 1". I have this message "disk assign: disk 0d.01.5 cannot be assigned to pool 1. Other disks on the loop are assigned to pool 0."
Do you have any ideas how i can assign this disk to the other spool ?
For information, when i make juste the command "disk assign 0d.01.5" the disk is automaticaly assigned to the spool0.
Sorry for my bad english, i hope you can understand me.
Thank you for your help.
rmontavonsa
i have found the command for switching spare disk to pool0 to pool1.
Firstime, you need to remove disk ownership with the command "disk remove_ownership 0d.01.5"
Now you can see the disk with the command "disk show -n"
After this, you can make the command "disk assign 0d.01.5 -p 1 -f"
But i have an other problem, i have always the message "There are not enough spare disks. /aggr0/plex0/rg0: Please add spare disks to any pool supporting block checksums with minimum " on the controller.
Do you have any ideas how i can resolve the problem ?
