ONTAP Hardware
how to rename NetApp C-Mode System Name / Filer?
VIRTUALGEEK2
I need to rename the  System Name / Filer on our C-Mode from ABCDE001_HJK to HAPPY001?
What is required?
Is there an outage?
How do I go about changing this?
Thanks,
VG
5 REPLIES 5
aborzenkov
Do you mean cluster itself or single cluster node? For cluster node - “system node rename”. There is no outage.
VIRTUALGEEK2
the netbios name, the name that is registered in AD. the name that you see when you click on the the vServer and the on the cifs protocol in the right hand window
aborzenkov
Just recreate CIFS service for vserver?
VIRTUALGEEK2
The is the long way around, is there no way to rename?
aaaaaaaaaaaaaaaaaa
cluster identity modify
