ONTAP Hardware
max open files on FAS3220
olivev
hi all,
is there limits on max open files on cifs on a fas3220 ?
regards
1 REPLY 1
georgevj
Check this, https://fieldportal.netapp.com/Modules/FieldPortal/Binders/Content.aspx?contentID=273471#2
If you dont have access to field portal, please contact NetApp tech support for an answer.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Cannot find the answer you need? No need to open a support case - just CHAT and we’ll handle it for you.
