ONTAP Hardware
netapp noob question
JOCO_PH168
hi,
when purchasing netapp, does it include already the hdd tray?  or do i need to buy the hdd from netapp?
thanks.
JoJo
2 REPLIES 2
aborzenkov
FAS2000 series are integrated (controller with + disks in one enclosure). Other models need extra disk enclosure. What exactly you get depends on what you order – it is up to you ☺
There is so called v-Series which allows you to connect third-party storage systems as backend storage. But if you need native disks, then yes, you have to use those from NetApp.
NETAPPCYP
JoJo, you can't insert of the market/shelf disks into a NetApp system. They need to be purchased from NetApp as the do some fine tuning to the disk firmware for compatibility. Also another to ensure an income .
