ONTAP Hardware
ontap 8.0.1 on fas 2040
chasejmillerjohnson
Anyone running 8.0.1 on a fas204?  if so any issues?  I really would like to use the VAAI capabilities with our VMware infrastructure and can't wait to move to this latest release.
9 REPLIES 9
ekashpureff
The 2040 is not supported.
See: https://now.netapp.com/NOW/knowledge/docs/ontap/rel801rc3/html/ontap/rnote/frameset.html
I hope this response has been helpful to you.
At your service,
Eugene E. Kashpureff
[email protected]
Fastlane NetApp Instructor and Independent Consultant
http://www.linkedin.com/in/eugenekashpureff http://www.kashpureff.org/
(P.S. I appreciate points for helpful or correct answers.)
bchase
It should be supported... they offer 8.0.1 RC3 as available for download... see image
peluso
Hi - I forwarded this along for answers.
Terri
Thanks so much!
Terri Peluso
Senior Community Program Manager
ashabbas1
We installed 8.0.1 RC3 on our 2040.  No problems.  We don't have a vmware shop, so I can address that.
pascalduk
Here also 8.0.1.RC3 and so far no issues found.
chasejmillerjohnson
Per that same link you sent I see the following showing the 2040 is supported…….
Supported systems
You need one of the supported storage systems listed in this section to run Data ONTAP 8.0 7-Mode or later Data ONTAP 8.0.x 7-Mode releases.
The following FAS and V-series storage systems are supported:
  • 60xx
  • 3140
  • 3160
  • 3170
  • 3040
  • 3070
  • 2040
  • 32xx
  • 62xx
Jeff D. Chase
VMware Certified Professional
Sr. Systems Analyst
250 Monroe Avenue NW, Suite 800
P.O. Box 306
Grand Rapids, MI 49501-0306
616.831.1929
616.988.1929 Fax
[email protected]
NOTICE: This communication may contain confidential information intended for the named recipient(s) only. If you received this by mistake, please destroy it and notify us of the error. Thank you.
Treasury Circular 230 Disclosure: This communication cannot be used for: avoiding Federal tax-related penalties, or (ii) promoting, marketing or recommending anything that is tax-related.
ekashpureff
Oops ! It is on there.
I'd read through once and didn't see the 2XXX systems.
At your service,
[email protected]
sshapiro
Checking AutoSupport, I found more than 200 FAS2040s that are running Data ONTAP 8.0.1 7-Mode.  While I don't have information about any specific customer deployments, the sheer numbers are an indication of the quality and stability of the release overall and usage with FAS2040.
Data ONTAP 8.0.1 7-Mode field adoption and customer experience meet GA criteria, and were it not for additional RC releases needed to complete support for the new FAS/V6200 and 3200 systems, the release would have already been declared GA.
I encourage you move ahead with plans to upgrade to Data ONTAP 8.0.1 7-Mode.
chasejmillerjohnson
Thanks for the info sshapiro! Definitely helps my decision making when I have info directly from netapp.
Jeff D. Chase
Sr. Systems Analyst
P.O. Box 306
616.831.1929
616.988.1929 Fax
[email protected]
