ONTAP Hardware
problem with hw_assist
ANTONIO_SIMULA
Hi All,
I have a problem with setting up of "cf.ha_assist".
when try to start command cf.ha_assist test, i have this output:
cf hw_assist Error: No response from partner(XXXX), timed out.
i use the e0M interface for cf.ha_assist.
from the cf hw_assist status command i see this output:
Thu Jul 10 22:14:46 CEST [IXXX:cf.hwassist.Default.NodemgmtAddr:notice]: The system automatically chose 192.168.X.X as the local hardware-assist IP address.
Thu Jul 10 22:15:07 CEST [XXX:cf.hwassist.socBindFailed:error]: hw_assist: bind failed to port 4444 on IP address 192.168.X.X Error 49
the netapp system is Fas2240-4 with data ontap 8.2.1
can you help me ?
thanks for support
Regards
Antonio
4 REPLIES 4
resqme914
Did you set up your SP properly?
JGPSHNTAP
I don't know your rc file setup, but whats wrong with using your filers vif ip
bhanojiraog7
please share the "options cf" command output.
ANTONIO_SIMULA
Hi All, soory for delay,
follow the output of "options cf":
first node:
cf.giveback.auto.after.panic.takeover on
cf.giveback.auto.cancel.on_network_failure on
cf.giveback.auto.cifs.terminate.minutes 5
cf.giveback.auto.delay.seconds 600
cf.giveback.auto.enable      off
cf.giveback.auto.override.vetoes off
cf.giveback.check.partner    on
cf.hw_assist.enable          off
cf.hw_assist.partner.address 192.168.X.Y
cf.hw_assist.partner.port    4444
cf.mode                      ha
cf.remote_syncmirror.enable  off        (same value required in local+partner)
cf.sfoaggr_maxtime           120        (value might be overwritten in takeover)
cf.takeover.bypass_optimization off
cf.takeover.change_fsid      on
cf.takeover.detection.seconds 15
cf.takeover.on_disk_shelf_miscompare off
cf.takeover.on_failure       on
cf.takeover.on_network_interface_failure on
cf.takeover.on_network_interface_failure.policy all_nics   (same value in local+partner recommended)
cf.takeover.on_panic         on
cf.takeover.on_reboot        off
cf.takeover.on_short_uptime  on
cf.takeover.use_mcrc_file    off
second node:
cf.mode                      ha
thanks
