ONTAP Hardware
save command
mark_zhang
Hi, I tried to login sp and system console to my Netapp FAS3140. I configure my network part. But sometime I found my configuration lost after I logout.
So my question is if there are some command need to run to save my change?
Thanks!
1 REPLY 1
HARI_KRISHNA981
Hi Mark.zhang,
The filer reads the /etc/rc on boot up to load the network information. You have to add it there to make any network configurations permanent.
Have you updated the changes in the /etc/rc??
Regards,
Hari.
