ONTAP Hardware
How to create a spare disk
johnny_lin
hi all,
I'm a flash man in netapp storage world. i have some questiosn about the setting of spare disk of FAS2040.
DETAILS:
version: 7.3.4
status:
"There are not enough spare disks. /aggr0/plex0/rg0: Please add spare disks to
any pool supporting block checksums with minimum"
NIS-IDD-Filer2> sysconfig -r
Aggregate aggr0(1) (failed, raid_dp, foreign, partial) (block checksums)
  Plex /aggr0(1)/plex0 (offline, failed, inactive)
    RAID group /aggr0(1)/plex0/rg0 (partial)
      RAID Disk Device  HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
      dparity   FAILED          N/A                   847555/1735794176
      data      FAILED          N/A                   847555/1735794176
      data      0c.00.9 0c    0   9   SA:B   0  SATA  7200 847555/1735794176 847884/1736466816
      Raid group is missing 5 disks.
Aggregate aggr0 (online, raid_dp) (block checksums)
  Plex /aggr0/plex0 (online, normal, active, pool0)
    RAID group /aggr0/plex0/rg0 (normal)
      dparity   0c.00.0 0c    0   0   SA:B   0  SATA  7200 847555/1735794176 847884/1736466816
      parity    0c.00.2 0c    0   2   SA:B   0  SATA  7200 847555/1735794176 847884/1736466816
      data      0c.00.4 0c    0   4   SA:B   0  SATA  7200 847555/1735794176 847884/1736466816
      data      0c.00.7 0c    0   7   SA:B   0  SATA  7200 847555/1735794176 847884/1736466816
      data      0c.00.6 0c    0   6   SA:B   0  SATA  7200 847555/1735794176 847884/1736466816
      data      0c.00.8 0c    0   8   SA:B   0  SATA  7200 847555/1735794176 847884/1736466816
Pool1 spare disks (empty)
Pool0 spare disks (empty)
what i wanna do is setting device 0c.00.9 as a spare disk for aggr0, then what should i do?
thank you in advcance.
BR
Lin
2 REPLIES 2
aborzenkov
You need to destroy foreign aggregate aggr0(1). Any disk not part of aggregate will be spare disk.
johnny_lin
great, after i destoried aggr0(1), device 0c.00.9 becomes spare disk automaticly and the system's global staus also becomes normal.
thx man !
