Object Storage
StorageGrid maximum capacity per node
Jackiez
Hi, Experts,
      In SG TR-4889,  when deploy SG on a bare metal or virtual host platform, there is limit per storage node as below:
− Maximum number of object store volumes per Storage Node: 16
− Maximum object store size: 36 TiB (39 TB)
     That means maximum capacity per node is 16 volumes*39TB =624TB.
     Do you have experience to deploy higher capacity than the limit/node ?
Rgds,
Jackie
4 REPLIES 4
Amitra
HI @Jackiez
As per documentation for GRID 11.7, this is the limit for software-based Storage Node:
The maximum tested LUN size is 39 TB.
A software-based Storage Node can have 1 to 16 storage volumes—​3 or more storage volumes are recommended. Each storage volume should be 4 TB or larger.
Note: An appliance Storage Node can have up to 48 storage volumes.
Jackiez
Amitra,
   Thansk for your information !  Since need software-based storage node , so we filed FVPR for that.
aronk
Correct, those are the limits for software defined deployments. I suggest filing an FPVR if you have a need to go larger.
Jackiez
Thanks Aronk !  Already filed FPVR for that .
