PowerShell Discussions
Enabling Storage Failover and Disable Auto-Giveback
MattBaldwin
Does the powershell toolkit have the ability to enable storage failover and disable auto-giveback?
Similar to these commands:
storage failover modify -node nodename -enabled true
storage failover modify -node nodename -auto-giveback false
storage failover modify -node nodename -auto-giveback-after-panic false
1 ACCEPTED SOLUTION
mbeattie
Hi Matt,
I'm not sure if the storage failover configuration can be modified by a PSTK CmdLet however you can always use the private REST CLI to invoke a CLI via the REST API. You could create a script with input parameters for the cluster/node name etc and have it invoke those commands. Here's an example script of using the private REST CLI: https://community.netapp.com/t5/ONTAP-Rest-API-Discussions/REST-API-snapmirror-relationships-create-with-a-schedule/td-p/437466
Hope that helps
/Matt
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
2 REPLIES 2
mbeattie
Hi Matt,
Hope that helps
/Matt
MattBaldwin
Thank you.  Seem like there needs to be some updates to the toolkit..  🙂
