SolidFire and HCI
DR setup on third party storage || production running on solidfire
panks2020
We are currently looking for a solution to replicate data from Netapp Solidfire array in production to another vendor's array(EMC VNX unified box) in DR.  We have Brocade6520 switches at DR site.
total data needs to be replicated is ~20tb
Total distace b/w sites is 90 km
total iops requirement 16000k
can netapp vasa applicance or Edge be used to seup DR?
Can Recoverpoint appliance be used at production site to setup replication. I heard we can use switch level splitter to setup the replication.
Compatibility matrix to setup DR between non netapp array.
Please suggest what would be the best solution to meet this requirement.
Thankyou !!
1 REPLY 1
infonet
Hi,
I'm very familiar with SolidFire or RecoveryPoint but I am pretty much sure this is Mission: Impossible 6 without Tom Cruz :-). You will need to use one of storage agnostic replication engines like Zerto, Arcserve etc ... Veeam maybe. If you are running vmware and you need low RPO and RTO, Zerto may be an answer.
Best regards,
D
