Object Storage
access deny for module org_info from Galaxy Collection 2.11.0
HENDRIK_LOESCHEN
Hi, just tested Galaxy Collection 2.11.0.
I tested Module na_sg_org_info and received an access denied.
I used the default Grid Admin user root and also created a new one with an admin group.
The same token worked without problems for Module na_sg_grid_info.
Ansible Error message is: "msg": {"developerMessage": "User (name, id) = (root, 00000000-0000-0000-0000-000000000000) does not have the following permission(s): administerTenant", "key": "error.403", "text": "Forbidden. You do not have permission to access this resource. Contact your StorageGRID administrator if you require access."}}
1 ACCEPTED SOLUTION
elementx
"You do not have permission to access this resource" (that is, to administerTenant).
I'd try with a tenant admin account for that tenant.
2 REPLIES 2
elementx
HENDRIK_LOESCHEN
yes. Only the tenant auth token is usable with this module.
