Tech ONTAP Blogs
Simplifying disaster recovery with Trident SnapMirror volume replication for NVMe/TCP
DhruvKharkwal
NetApp
In today's fast-paced digital world, keeping your data safe and always available is more critical than ever. As enterprises increasingly depend on Kubernetes to deploy and manage their applications, having a robust disaster recovery plan is essential. Enter NetApp® Trident™ with asynchronous SnapMirror® volume replication to keep your data secure and your mind at ease.
With the release of v25.06,  Trident now supports NVMe/TCP back ends for volume replication using SnapMirror, offering faster and more efficient data transfer capabilities. This blog takes you through the exciting journey of setting up asynchronous SnapMirror volume replication using Trident. So buckle up and let’s dive in!
Why SnapMirror volume replication?
NetApp SnapMirror technology is a game changer for disaster recovery, enabling efficient data replication between NetApp ONTAP® clusters. With Trident, you can establish mirror relationships between PersistentVolumeClaims (PVCs) on different ONTAP clusters, so that your data is always protected and available. Here’s why you should be excited about these mirror relationships:
  • Disaster recovery. With SnapMirror. your data is replicated and ready to go in case of any disaster.
  • Seamless failover. Easily promote secondary volumes during unplanned failovers and perform smooth transitions during planned migrations.
  • Custom Resource Definition (CRD). Manage mirror relationships effortlessly with the Trident Mirror Relationship (TMR) CRD.
Prerequisites: Ready, set, go!
Before we get started, make sure that you have the following in place:
  • ONTAP clusters: Both source and destination clusters must have ONTAP SnapMirror asynchronous licenses enabled. Refer to SnapMirror licensing overview in ONTAP for more information. To use Trident SnapMirror Volume Replication with NVMe/TCP, the ONTAP version must be 9.15.1 or later.
    Create a
    cron job on the destination cluster for an asynchronous replication schedule, Example command:
    cron create -name five_minute -minute 0,5,10,15,20,25,30,35,40,45,50,55
  • Peering: ONTAP clusters are in cluster peering, and the storage virtual machines (SVMs)  of the source and destination clusters are in vserver peering.
  • Trident. Trident version should be 25.06 or later.
Setting up SnapMirror volume replication for NVMe/TCP with a step-by-step example.
  • Create Trident back end for source cluster. Start by creating a Trident back end with the storage driver ontap-san. You can do this either by configuring the TridentBackendConfig (TBC) custom resource definition using the Kubernetes-native approach or by using a custom JSON file with tridentctl, a command-line utility for managing Trident. The configuration is similar to any other ontap-san NVMe back end, with the only changes being the username and password. You can either use a cluster management IP with administrator credentials or specify a storage virtual machine with its management IP and credentials. For more information, refer to ONTAP SAN driver details.
    # Kubernetes secret required for creating Trident backend from TBC
    [root@scs000646264 artifacts]# cat primary-secret.yaml
    apiVersion: v1
    kind: Secret
    metadata:
    type: Opaque
    stringData:
    username: <username>
    password: <password>
    [root@scs000646264 artifacts]# kubectl create -f primary-secret.yaml -n trident
    secret/primary-tbc-secret created
  • Add the back end. When the back end is configured, you can add it to Trident by using either kubectl or tridentctl. These tools are a convenient way to add the newly configured back end to Trident and make it available for use.
    # Kubernetes CR TridentBackendConfig (TBC)
    [root@scs000646264 artifacts]# cat primary-tbc.yaml---
    kind: TridentBackendConfig
    metadata:
    spec:
      version: 1
      storageDriverName: ontap-san
      sanType: nvme
      managementLIF: 8.8.8.8
      svm: svm0
      credentials:
    [root@scs000646264 artifacts]# kubectl create -f primary-tbc.yaml -n trident
    tridentbackendconfig.trident.netapp.io/primary-backend-tbc created
    [root@scs000646264 artifacts]# kubectl get tbc -n trident
    NAME                    BACKEND NAME            BACKEND UUID                           PHASE   STATUS
    primary-backend-tbc     primary-backend-tbc     a9b1a3a7-66a8-4d3b-984a-b87d851387c7   Bound   Success
    # Or, Trident backend json
    [root@scs000646264 artifacts]# cat backend.json
        "version": 1,
        "storageDriverName": "ontap-san",
        "managementLIF": "8.8.8.8",
        "backendName": "primary-backend"
        "svm": "svm0",
        "username": "<username>",
        "password": "<password>",
        "sanType": "nvme"
    [root@scs000646264 artifacts]# tridentctl create b -f primary-backend.json -n trident
    |        NAME        | STORAGE DRIVER |                 UUID                 | STATE  | USER-STATE | VOLUMES |
    | primary-backend    | ontap-san      | 6458337e-a27e-4cde-8707-0f6218214356 | online | normal     |       0 |
  • Define a storage class. Create a storage class that corresponds to the type of storage driver you need. This step allows you to define the characteristics of the storage that you want to dynamically provision.
    kind: StorageClass
    metadata:
    parameters:
      backendType: ontap-san
      storagePools: primary-backend-tbc:.*
    allowVolumeExpansion: true
    root@scs000646264 artifacts]# kubectl create -f primary-sc.yaml
    storageclass.storage.k8s.io/primary-sc created
    [root@scs000646264 artifacts]# kubectl get sc
    NAME           PROVISIONER             RECLAIMPOLICY   VOLUMEBINDINGMODE   ALLOWVOLUMEEXPANSION   AGE
    primary-sc     csi.trident.netapp.io   Delete          Immediate           true                   2s
  • Create a PVC. Define a PersistentVolumeClaim that specifies the amount of storage you need and references the appropriate storage class. This step ensures that your Kubernetes application has access to the required block storage.
    kind: PersistentVolumeClaim
    apiVersion: v1
    metadata:
    spec:
      accessModes:
        - ReadWriteOnce
      resources:
        requests:
          storage: 20Mi
      storageClassName: primary-sc
    [root@scs000646264 artifacts]# kubectl create -f primary-pvc.yaml
    persistentvolumeclaim/primary-pvc created​
  • Confirm PVC binding. After the PVC is created, verify that it’s successfully bound to a persistent volume (PV). This step confirms that the block storage is ready for use by your applications.
    [root@scs000646264 artifacts]# kubectl get pvc
    NAME          STATUS   VOLUME                                     CAPACITY   ACCESS MODES   STORAGECLASS   VOLUMEATTRIBUTESCLASS   AGE
    primary-pvc   Bound    pvc-bd77f21b-4522-41e9-bfa1-fca7cf8af672   20Mi       RWO            primary-sc     <unset>                 4s
  • Use the PVC. You’re now ready to use the PVC in any pod of your choice. Mount the PVC in a pod to store data.
    The following example simulates an application workload. This pod runs an Nginx container, writing timestamps to a file on the PVC every 20 seconds.
    [root@scs000646264 artifacts]# cat pod.yaml
    apiVersion: v1
    kind: Pod
    metadata:
    spec:
      containers:
        - image: nginx:alpine
          volumeMounts:
            - mountPath: /pv/pvc
          command: ["/bin/ash", "-c"]
          args:
              while true; do
                echo `date +%Y-%m-%d.%H:%M:%S` >> /pv/pvc/data.txt;
                fsync /pv/pvc;
                fsync /pv/pvc/data.txt;
                tail -n 1 /pv/pvc/data.txt;
                sleep 20;
              done
      nodeSelector:
        kubernetes.io/arch: amd64
        kubernetes.io/os: linux
      volumes:
        - name: local-storage
          persistentVolumeClaim:
            claimName: primary-pvc
    [root@scs000646264 artifacts]# kubectl create -f pod.yaml
    pod/source-pod created
    [root@scs000646264 artifacts]# kubectl get po
    NAME         READY   STATUS              RESTARTS   AGE
    source-pod   1/1     Running             0          15s
    [root@scs000646264 artifacts]# kubectl logs source-pod
    2025-05-21.07:30:12
    2025-05-21.07:30:32
  • Create  source MirrorRelationship custom resource (CR) with local information (localPVCName).
    Trident fetches the internal information for the volume and the volume’s current data protection (DP) state, then populates the status field of the MirrorRelationship.
    kind: TridentMirrorRelationship
    metadata:
    spec:
    state: promoted
    volumeMappings:
    - localPVCName: primary-pvc
    [root@scs000646264 artifacts]# kubectl create -f source-tmr.yaml
    tridentmirrorrelationship.trident.netapp.io/source-tmr created
    [root@scs000646264 artifacts]# kubectl get tmr
    NAME         DESIRED STATE   LOCAL PVC     ACTUAL STATE   MESSAGE
    source-tmr   promoted        primary-pvc   promoted
  • Get the TridentMirrorRelationship CR to obtain the internal name and SVM of the PVC.
    [root@scs000646264 artifacts]# kubectl get tmr source-tmr -o yaml
    metadata:
      creationTimestamp: "2025-05-21T07:26:15Z"
      finalizers:
      - trident.netapp.io
      generation: 2
      namespace: default
      resourceVersion: "4573176"
      uid: 7d0cb8e2-434a-4c1b-b3a8-8d181f744f82
    spec:
      replicationPolicy: ""
      replicationSchedule: ""
      state: promoted
      volumeMappings:
        promotedSnapshotHandle: ""
        remoteVolumeHandle: ""
    status:
      conditions:
      - lastTransitionTime: "2025-05-21T07:26:15Z"
        localVolumeHandle: svm0:trident_pvc_bd77f21b_4522_41e9_bfa1_fca7cf8af672
        message: ""
        observedGeneration: 2
        state: promoted​
  • Perform the following steps for the destination cluster:
    Create Trident back end with a replicationPolicy of MirrorAllSnapshots.
    [root@scs000646264 artifacts]# cat secondary-secret.yaml
    apiVersion: v1
    kind: Secret
    metadata:
    type: Opaque
    stringData:
    [root@scs000646264 artifacts]# kubectl create -f secondary-secret.yaml -n trident
    secret/secondary-tbc-secret created
    [root@scs000646264 artifacts]# cat secondary-tbc.yaml
    metadata:
    spec:
      version: 1
      sanType: nvme
      managementLIF: 7.7.7.7
      svm: svm1
      replicationPolicy: MirrorAllSnapshots
      replicationSchedule: five_minute
      credentials:
    [root@scs000646264 artifacts]# kubectl create -f secondary-tbc-tamu.yaml -n trident
    tridentbackendconfig.trident.netapp.io/secondary-backend-tbc created
    secondary-backend-tbc   secondary-backend-tbc   c4fbde1a-cf6c-4ee4-8474-488454c926d1   Bound   Success
        "version": 1,
        "managementLIF": "7:7:7:7",
        "backendName": "secondary-backend"
        "svm": "svm0",
        "sanType": "nvme"
        "replicationPolicy": "MirrorAllSnapshots"
        "replicationSchedule": "five_minute"
    | secondary-backend    | ontap-san    | 2345337e-e67e-4bdm-8707-1d5644326548 | online | normal     |       0 |
  • Create destination storage class.
    [root@scs000646264 artifacts]# cat secondary_sc.yaml
    apiVersion: storage.k8s.io/v1
    kind: StorageClass
    metadata:
    parameters:
      storagePools: secondary-backend-tbc:.*
    [root@scs000646264 artifacts]# kubectl create -f secondary_sc.yaml
    storageclass.storage.k8s.io/secondary-sc created
    primary-sc     csi.trident.netapp.io   Delete          Immediate           true                  11s
    secondary-sc   csi.trident.netapp.io   Delete          Immediate           true                   3s
  • Create destination PVC with previously created StorageClass to act as the secondary (SnapMirror destination).
    Trident checks for the TridentMirrorRelationship CRD. If the relationship does not exist, Trident fails to create the volume and remains in pending state until the destination TMR is created.
    If the relationship exists, Trident places the new FlexVol volume onto an SVM that is peered with the remote SVM defined in the MirrorRelationship.
    [root@scs000646264 artifacts]# cat secondary-pvc.yaml
    apiVersion: v1
    metadata:
      annotations:
        trident.netapp.io/mirrorRelationship: dest-tmr
    spec:
      accessModes:
        - ReadWriteOnce
      resources:
        requests:
          storage: 20Mi
      storageClassName: secondary-sc
    [root@scs000646264 artifacts]# kubectl create -f secondary-pvc.yaml
    persistentvolumeclaim/secondary-pvc created
    primary-pvc     Bound     pvc-bd77f21b-4522-41e9-bfa1-fca7cf8af672   20Mi       RWO            primary-sc     <unset>                 43s
    secondary-pvc   Pending        secondary-sc   <unset>                 4s
  • Create destination TMR CR.
    Trident creates a SnapMirror relationship with the configured relationship policy name (or default for ONTAP) and initializes it. (Provide the value obtained in “Get the TridentMirrorRelationship CR to obtain the internal name and SVM of the PVC,” earlier in this document, as the remoteVolumeHandle in destination TMR CR.)
    kind: TridentMirrorRelationship”
    metadata:
    spec:
      state: established
      volumeMappings:
        - localPVCName: secondary-pvc
          remoteVolumeHandle: "svm0:trident_pvc_bd77f21b_4522_41e9_bfa1_fca7cf8af672"
    [root@scs000646264 artifacts]# kubectl create -f dest-tmr.yaml
    tridentmirrorrelationship.trident.netapp.io/dest-tmr created
    dest-tmr     established     secondary-pvc   established
    Verify the SnapMirror relationship and volume type (DP) on the destination cluster:
    stiA300-2491746692774::> snapmirror show
        Progress
    Source            Destination Mirror  Relationship   Total             Last
    Path        Type  Path        State   Status         Progress  Healthy Updated
                XDP  svm1:trident_pvc_32d31b4d_ec91_41cd_a95e_9e74bd6b2d9b
                                  Snapmirrored
                                          Idle           -         true    -
    stiA300-2491746692774::> volume show -vserver svm1
    Vserver   Volume       Aggregate    State      Type       Size  Available Used%
    svm1      svm0_root    stiA300_250_aggr1
                                        online     RW          1GB    972.4MB    0%
    svm1      trident_pvc_32d31b4d_ec91_41cd_a95e_9e74bd6b2d9b
                           stiA300_249_aggr1
                                        online     DP         22MB    20.42MB    7%
    2 entries were displayed.
    Create snapshot class
    [root@scs000646264 artifacts]# cat snapshot-class.yaml
    apiVersion: snapshot.storage.k8s.io/v1
    kind: VolumeSnapshotClass
    metadata:
    driver: csi.trident.netapp.io
    deletionPolicy: Delete
    [root@scs000646264 artifacts]# kubectl create -f snapshot-class.yaml
    volumesnapshotclass.snapshot.storage.k8s.io/csi-snapclass created
    [root@scs000646264 artifacts]#  kubectl get volumesnapshotclasses
    NAME            DRIVER                  DELETIONPOLICY   AGE
    csi-snapclass   csi.trident.netapp.io   Delete           5s
    Below is the output for the snapshot show command in the Destination cluster, Before any snapshot is created.
    stiA300-2491746692774::> snapshot show
        ---Blocks---
    Vserver  Volume   Snapshot                                  Size Total% Used%
                      snapmirror.33ffbac2-300c-11f0-8dc5-00a098f48d3e_2155208310.2025-05-21_032847
                                                               216KB     1%   40%
                      snapmirror.33ffbac2-300c-11f0-8dc5-00a098f48d3e_2155208310.2025-05-21_033000
                                                               136KB     1%   29%
  • Create snapshot
    metadata:
    spec:
    volumeSnapshotClassName: csi-snapclass
    source:
    persistentVolumeClaimName: primary-pvc
    root@scs000646264 artifacts]# kubectl create -f snapshot.yaml
    volumesnapshot.snapshot.storage.k8s.io/snap1 created
    [root@scs000646264 artifacts]# kubectl get volumesnapshots
    NAME    READYTOUSE   SOURCEPVC     SOURCESNAPSHOTCONTENT   RESTORESIZE   SNAPSHOTCLASS   SNAPSHOTCONTENT                                    CREATIONTIME   AGE
    snap1   true         primary-pvc                           20Mi          csi-snapclass   snapcontent-7a3b0380-6d13-4cb9-88a3-df9528be73a9   5s             6s
    Output of the
    snapshot show command in the destination cluster after the first Snapshot copy is taken:
        ---Blocks---
                                                               216KB     1%   19%
                      snapshot-7a3b0380-6d13-4cb9-88a3-df9528be73a9
                                                               268KB     1%   22%
                      snapmirror.33ffbac2-300c-11f0-8dc5-00a098f48d3e_2155208310.2025-05-21_033740
                                                               180KB     1%   16%
    3 entries were displayed.​
    Working with more Snapshot copies:
    metadata:
    spec:
    source:
    root@scs000646264 artifacts]#  kubectl create -f snapshot-1.yaml
    volumesnapshot.snapshot.storage.k8s.io/snap1-new created
    [root@scs000646264 artifacts]# kubectl get vs
    snap1       true         primary-pvc                           20Mi          csi-snapclass   snapcontent-7a3b0380-6d13-4cb9-88a3-df9528be73a9   6m33s          6m34s
    snap1-new   true         primary-pvc                           20Mi          csi-snapclass   snapcontent-56cf40dc-f968-4aeb-9ffd-ea1f7bcf0942   4s             5s
    Snapshots transfer ensures the replication process.
        ---Blocks---
                                                               268KB     1%   20%
                                                               276KB     1%   21%
                      snapshot-56cf40dc-f968-4aeb-9ffd-ea1f7bcf0942
                                                               264KB     1%   20%
                      snapmirror.33ffbac2-300c-11f0-8dc5-00a098f48d3e_2155208310.2025-05-21_034000
                                                               272KB     1%   21%
    4 entries were displayed.
    In Trident, when the state of the destination TMR is established, it indicates that the destination volume is a Data Protection (DP) volume. DP volumes are used for replication and backup, so  that your data is protected and can be recovered in case of failure.
    To verify that the destination volume is indeed a DP volume, you can use the volume show command:
    stiA300-249
              vol0         aggr0_stiA300_249
                                        online     RW      348.6GB    291.9GB   11%
    stiA300-250
              vol0         aggr0_stiA300_250
                                        online     RW      348.6GB    291.7GB   11%
                           stiA300_249_aggr1
                                        online     DP         22MB    19.93MB    9%
    vs0       root_vs0     stiA300_249_aggr1
                                        online     RW          1GB    972.1MB    0%
    5 entries were displayed.
Volume replication states
The TMR CRD has the following states to manage the replication relationship:
  1. Established. When the state of destination TMR is established, it indicates that the destination volume is a Data Protection (DP) volume. DP volumes are used for replication and backup, so that your data is protected and can be recovered in case of failure.
  2. Promoted. When the TMR state is promoted, it indicates that the destination volume has been elevated to become the new source volume. This means that the destination volume is now writable and can serve I/O operations, effectively taking over the role of the original source volume.
  3. Reestablished. The TMR state is reestablished after failover  when the original source volume is ready to resume its role as the primary volume. This typically occurs in scenarios where the original issue that caused the failover has been resolved or maintenance has been completed, and you want to revert the roles of the source and destination volumes to their original configuration. When the TMR state is reestablished, it indicates that the replication relationship between the source and destination volumes has been restored to its original state.
  • Promote secondary PVC during an unplanned failover
    Perform the following step on the secondary Kubernetes cluster:
    Update the spec.state field of TridentMirrorRelationship to promoted.
    metadata:
    spec:
      state: promoted
      volumeMappings:
    [root@scs000646264 artifacts]# kubectl apply -f dest-tmr.yaml
    tridentmirrorrelationship.trident.netapp.io/dest-tmr configured
    dest-tmr     promoted        secondary-pvc   promoted
    Once the destination TMR is promoted, the destination volume becomes the  RW volume with no mirror relationship currently in effect.
    Check the volume state and snapmirror:
    This table is currently empty.
    stiA300-249
    stiA300-250
                           stiA300_249_aggr1
                                        online     RW         22MB    19.93MB    9%
    When TMR is in promoted state, you can mount applications with the destination PVC.
    Test the promoted PVC by mounting it in a pod:
    apiVersion: v1
    kind: Pod
    metadata:
    spec:
      containers:
        - name: test-container
          image: nginx:alpine
          imagePullPolicy: IfNotPresent
          volumeMounts:
            - mountPath: /mnt/test-path
              readOnly: false
      restartPolicy: Never
      volumes:
        - name: test-volume
            claimName: secondary-pvc
            readOnly: false
    [root@scs000646264 artifacts]# kubectl create -f test-pod.yaml
    source-pod   1/1     Running             0          12m
    test-pod     1/1     Running             0          8s
  • Restore a mirror relationship after a failover
    The TMR state is reestablished after a failover or planned switchover operation when the original source volume is ready to resume its role as the primary volume.
    metadata:
    spec:
      state: reestablished
      volumeMappings:
    snapmirror show output:
        Progress
                                  Snapmirrored
                                          Idle           -         true    -
Conclusion: Your data, unstoppable!
With NetApp Trident and SnapMirror, you’ve built a robust disaster recovery pipeline for your Kubernetes applications. Every file—secrets, back ends, storage classes, PVCs, TMRs, Snapshot copies, and pods—plays a critical role in making sure that your data is replicated, protected, and ready for any scenario. Follow the steps in this guide and your clusters will be prepared to handle disasters with confidence.
Additionally, check out Trident protect, which helps you to manage SnapMirror and fail over the data, and also to manage the complete application. For more detailed information on using SnapMirror replication with Trident protect, check out the NetApp Trident protect documentation.
Want to dive deeper? Check out the NetApp Trident documentation for more insights. Happy replicating!
