Virtualization Environments
Proxmox openvswitches (OVS) not discovered by NetApp Shift Toolkit
Nesta
Hello,
I am attempting to test migrations from VMware to Proxmox via the NetApp Shift Toolkit. I have added the source and destination platforms into the toolkit, and discovery completes without issue.
On the VMware vSphere environment, the Networks are discovered.
But no Networks are discovered on the Proxmox VE environment.
This is causing a problem when I attempt to create a New Blueprint, as the Network Mapping is unvailable : "No more Destination network resources available for mapping"
If I select the test option, the “Do no configure Network” is the default selection, but still the same "No more Destination network resources available for mapping".
And when trying to continue creating the blueprint it fails with "Network Mapping can't be empty"
The environments are as follows:
VMware vSphere 7.0.3
ONTAP 9.16.1P10 (NFSv3)
Proxmox 9.1.1
Regards,
Jef
0 REPLIES 0
