AFF
Changing Default Volume Properties
Coleman
(Running ONTAP 9.5)
Does anyone know how to change the default properties of new volumes?
For example, all new volumes are created with an auto-grow threshold of 91%.
I'd like to change this value so that all volumes created in the future have an auto-grow threshold of 88%.
Thanks!
2 REPLIES 2
hmoubara
Hello,
Are you referring to the autosize-grow-threshold-percent?
Thanks
chenguanghui
hello:
  The default attribute of the new volume. Type is not a modifiable parameter. You need to use "" to create a new volume Type. For other attributes, you can run the "volume modify" command to modify the attribute parameters,I hope I can help you
Best regards!
