AFF
unable to access NetApp AFF storage web management page
JY18
Suddenly unable to access NetApp AFF storage web management page, don't do any operations or change on it before.
but can login it via SSH
showed below message when access the web mamaenet page
This site can’t be reachedThe webpage at https://ManagementIP/sysmgr/ might be temporarily down or it may have moved permanently to a new web address.
ERR_SSL_KEY_USAGE_INCOMPATIBLE
This is output when run command "system services web show" in SSH
External Web Services: true
HTTP Port: 80
HTTPS Port: 443
Protocol Status: online
Per Address Limit: 80
HTTP Enabled: false
2 REPLIES 2
cedric_renauld
Hello,
for my it's https://xx.xx.xx.xx/sysmgr/v4/, can you try ?
Or jsut the IP adress, the redirect must redirect you to the good page
Or this message : ERR_SSL_KEY_USAGE_INCOMPATIBLE
Have you try another web browser ?
Last chance it's could be an Certificat issue or expiration try to see this article :
https://kb.netapp.com/onprem/ontap/os/How_to_renew_a_Self-Signed_SSL_certificate_in_ONTAP_9
the command to check :
security certificate show -fields vserver,common-name,serial,ca,type,expiration -type server
chenguanghui
hello:
  The following two articles i hope to help you,if not you can only contact netAPP technical support staff. In  This case,you can only recover in diagnostic mode, and you must recover under the guidance of netAPP technical support personnel
https://docs.netapp.com/zh-cn/ontap/system-admin/troubleshoot-web-access-problems-concept.html
https://kb.netapp.com/on-prem/ontap/DM/System_Manager/SM-KBs/ONTAP_System_Manager_9_11_1_shows_ERR_SSL_KEY_USAGE_INCOMPATIBLE_due_to_unsupported_ciphe...
Best regards!
