Help - WFA cannot acquire from vcenter - timing out - need help deciphering jboss output
stephen2
All, I am working with a customer and we are under some time pressure. I opened a call but was hoping someone could take a look at this log entry and tell me what the problem might be.
Note - two vcenter servers - one is working fine. Also, I can browse to failing vcenter server from WFA on port 443 and log in, view inventory
Symptoms - datasource times out during acquisition
Actions - deleted and recreated datasource, restarted wfa server service
The complete log directory is attached (rename to .zip), but the following is the error message from the wfa-acq log:
Error running data acquisition script: Command '$Uri = @($input)[0] ; C:\Program` Files\NetApp\WFA\jboss\..\PoSH\profile.ps1;Invoke-WfaCommand -Script './vc_14056197513255252205659262553267.ps1 '' timed out
    at com.netapp.wfa.cache.execution.ScriptBasedExtractor.preProcess(ScriptBasedExtractor.java:45) [cache-0.5.jar:]
    at com.netapp.wfa.cache.execution.ETLRunner.extractToFiles(ETLRunner.java:103) [cache-0.5.jar:]
    at com.netapp.wfa.cache.job.CacheJobWorkerImpl.extractToFiles(CacheJobWorkerImpl.java:31) [cache-0.5.jar:]
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) [rt.jar:1.7.0_25]
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) [rt.jar:1.7.0_25]
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) [rt.jar:1.7.0_25]
    at java.lang.reflect.Method.invoke(Method.java:606) [rt.jar:1.7.0_25]
    at org.jboss.as.ee.component.ManagedReferenceMethodInterceptorFactory$ManagedReferenceMethodInterceptor.processInvocation(ManagedReferenceMethodInterceptorFactory.java:72) [jboss-as-ee-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.invocation.InterceptorContext.proceed(InterceptorContext.java:288) [jboss-invocation-1.1.1.Final.jar:1.1.1.Final]
    at org.jboss.invocation.WeavedInterceptor.processInvocation(WeavedInterceptor.java:53) [jboss-invocation-1.1.1.Final.jar:1.1.1.Final]
    at org.jboss.as.ee.component.interceptors.UserInterceptorFactory$1.processInvocation(UserInterceptorFactory.java:36) [jboss-as-ee-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.jpa.interceptor.SBInvocationInterceptor.processInvocation(SBInvocationInterceptor.java:47) [jboss-as-jpa-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.invocation.InitialInterceptor.processInvocation(InitialInterceptor.java:21) [jboss-invocation-1.1.1.Final.jar:1.1.1.Final]
    at org.jboss.invocation.ChainedInterceptor.processInvocation(ChainedInterceptor.java:61) [jboss-invocation-1.1.1.Final.jar:1.1.1.Final]
    at org.jboss.as.ee.component.interceptors.ComponentDispatcherInterceptor.processInvocation(ComponentDispatcherInterceptor.java:53) [jboss-as-ee-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ejb3.component.pool.PooledInstanceInterceptor.processInvocation(PooledInstanceInterceptor.java:51) [jboss-as-ejb3-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ejb3.tx.CMTTxInterceptor.invokeInNoTx(CMTTxInterceptor.java:211) [jboss-as-ejb3-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ejb3.tx.CMTTxInterceptor.never(CMTTxInterceptor.java:265) [jboss-as-ejb3-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ejb3.tx.CMTTxInterceptor.processInvocation(CMTTxInterceptor.java:186) [jboss-as-ejb3-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ejb3.component.interceptors.CurrentInvocationContextInterceptor.processInvocation(CurrentInvocationContextInterceptor.java:41) [jboss-as-ejb3-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ejb3.component.interceptors.LoggingInterceptor.processInvocation(LoggingInterceptor.java:59) [jboss-as-ejb3-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ee.component.NamespaceContextInterceptor.processInvocation(NamespaceContextInterceptor.java:50) [jboss-as-ee-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ejb3.component.interceptors.AdditionalSetupInterceptor.processInvocation(AdditionalSetupInterceptor.java:32) [jboss-as-ejb3-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ee.component.TCCLInterceptor.processInvocation(TCCLInterceptor.java:45) [jboss-as-ee-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ee.component.ViewService$View.invoke(ViewService.java:165) [jboss-as-ee-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ee.component.ViewDescription$1.processInvocation(ViewDescription.java:173) [jboss-as-ee-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ee.component.ProxyInvocationHandler.invoke(ProxyInvocationHandler.java:72) [jboss-as-ee-7.1.1.Final.jar:7.1.1.Final]
    at com.netapp.wfa.cache.job.CacheJobWorker$$$view77.extractToFiles(Unknown Source) [cache-0.5.jar:]
    at com.netapp.wfa.cache.job.CacheJobExecutorImpl.runETL(CacheJobExecutorImpl.java:114) [cache-0.5.jar:]
    at com.netapp.wfa.cache.job.CacheJobExecutorImpl.execute(CacheJobExecutorImpl.java:83) [cache-0.5.jar:]
    at org.jboss.invocation.InterceptorContext$Invocation.proceed(InterceptorContext.java:374) [jboss-invocation-1.1.1.Final.jar:1.1.1.Final]
    at com.netapp.wfa.common.stats.MethodInvocationStatsInterceptor.recordMethodInvocation(MethodInvocationStatsInterceptor.java:24) [common-0.5.jar:]
    at sun.reflect.GeneratedMethodAccessor309.invoke(Unknown Source) [:1.7.0_25]
    at org.jboss.as.ee.component.ManagedReferenceLifecycleMethodInterceptorFactory$ManagedReferenceLifecycleMethodInterceptor.processInvocation(ManagedReferenceLifecycleMethodInterceptorFactory.java:123) [jboss-as-ee-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ejb3.tx.CMTTxInterceptor.notSupported(CMTTxInterceptor.java:288) [jboss-as-ejb3-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ejb3.tx.CMTTxInterceptor.processInvocation(CMTTxInterceptor.java:188) [jboss-as-ejb3-7.1.1.Final.jar:7.1.1.Final]
    at com.netapp.wfa.cache.job.CacheJobExecutor$$$view83.execute(Unknown Source) [cache-0.5.jar:]
    at com.netapp.wfa.cache.job.CacheJobExecutorMDB.onMessage(CacheJobExecutorMDB.java:37) [cache-0.5.jar:]
    at com.netapp.wfa.job.backend.JobsExecutionInterceptor.wrapJobExecution(JobsExecutionInterceptor.java:62) [job-management-0.5.jar:]
    at sun.reflect.GeneratedMethodAccessor430.invoke(Unknown Source) [:1.7.0_25]
    at org.jboss.as.ejb3.component.interceptors.AdditionalSetupInterceptor.processInvocation(AdditionalSetupInterceptor.java:43) [jboss-as-ejb3-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ejb3.component.messagedriven.MessageDrivenComponentDescription$5$1.processInvocation(MessageDrivenComponentDescription.java:184) [jboss-as-ejb3-7.1.1.Final.jar:7.1.1.Final]
    at javax.jms.MessageListener$$$view43.onMessage(Unknown Source) [jboss-jms-api_1.1_spec-1.0.0.Final.jar:1.0.0.Final]
    at sun.reflect.GeneratedMethodAccessor429.invoke(Unknown Source) [:1.7.0_25]
    at org.jboss.as.ejb3.inflow.MessageEndpointInvocationHandler.doInvoke(MessageEndpointInvocationHandler.java:140) [jboss-as-ejb3-7.1.1.Final.jar:7.1.1.Final]
    at org.jboss.as.ejb3.inflow.AbstractInvocationHandler.invoke(AbstractInvocationHandler.java:73) [jboss-as-ejb3-7.1.1.Final.jar:7.1.1.Final]
    at com.sun.proxy.$Proxy159.onMessage(Unknown Source)
    at org.hornetq.ra.inflow.HornetQMessageHandler.onMessage(HornetQMessageHandler.java:278)
    at org.hornetq.core.client.impl.ClientConsumerImpl.callOnMessage(ClientConsumerImpl.java:983)
    at org.hornetq.core.client.impl.ClientConsumerImpl.access$400(ClientConsumerImpl.java:48)
    at org.hornetq.core.client.impl.ClientConsumerImpl$Runner.run(ClientConsumerImpl.java:1113)
    at org.hornetq.utils.OrderedExecutorFactory$OrderedExecutor$1.run(OrderedExecutorFactory.java:100)
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) [rt.jar:1.7.0_25]
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) [rt.jar:1.7.0_25]
    at java.lang.Thread.run(Thread.java:724) [rt.jar:1.7.0_25]
Caused by: CommandExecutionException{Message: Command '$Uri = @($input)[0] ; C:\Program` Files\NetApp\WFA\jboss\..\PoSH\profile.ps1;Invoke-WfaCommand -Script './vc_14056197513255252205659262553267.ps1 '' timed out, Cause: null}
    at com.netapp.wfa.command.execution.impl.executors.ScriptBasedCommandExecutor.executeScriptCommand(ScriptBasedCommandExecutor.java:169) [command-0.5.jar:]
    at com.netapp.wfa.command.execution.impl.executors.ScriptBasedCommandExecutor.executeScriptCommand(ScriptBasedCommandExecutor.java:67) [command-0.5.jar:]
    at com.netapp.wfa.command.execution.impl.executors.ScriptBasedCommandExecutor.execute(ScriptBasedCommandExecutor.java:46) [command-0.5.jar:]
    at com.netapp.wfa.cache.execution.ScriptBasedExtractor.preProcess(ScriptBasedExtractor.java:42) [cache-0.5.jar:]
1 ACCEPTED SOLUTION
sinhaa
This may not be a WFA issue exactly. Get-VMHostHBA and Get-ScsiLuns cmdlets can take a very long time to execute and perhaps causing the timeout. Does the VCenter have a lot of Scsi luns?
Try increasing the Timout value in the Datasource from 600 sec to let's say 5000 sec and acquire again.
refer to burt id: 828171 and my post on it.
sinhaa
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
2 REPLIES 2
sinhaa
sinhaa
stephen2
I've set it to 3600. I'll let you kno if it works
