Is it possible to monitor syncmirror aggregates using Oncommand?
surez_june
Hello all,
Is there way we can monitor syncmirror aggregates using Oncommand and generate events when they change state?
aggregates states like out-of-date, resyncing, mirror degraded etc.
Thanks,
Suresh
2 REPLIES 2
adaikkap
Hi Suresh,
     I checked the OCUM events and found that there are no events related to syncmirror aggr.
There is one attribute about Aggregate Mirrored, which should say if aggregate is sync mirrored or not.
lnx142-x2:~ # dfm report catalog list -R Aggregate | grep -i mirror
Mirrored                            Aggregate Mirrored
lnx142-x2:~ #
But we do have event for sync and semi sync snapmirrors.
lnx142-x2:~ # dfm eventtype list | grep -i sync
snapmirror-resync:aborted                     Warning      sm.resync
snapmirror-resync:completed                   Normal       sm.resync
snapmirror-resync:failed                      Error        sm.resync
sync-snapmirror:in-sync                       Information  sm.sync
sync-snapmirror:out-of-sync                   Warning      sm.sync
lnx142-x2:~ # dfm eventtype list | grep -i degrade
lnx142-x2:~ # dfm eventtype list | grep -i out
snapmirror:nearly-out-of-date                 Warning      sm.lag
snapmirror:out-of-date                        Error        sm.lag
snapvault-replica:nearly-out-of-date          Warning      snapvault-replica
snapvault-replica:out-of-date                 Error        snapvault-replica
lnx142-x2:~ #
Regards
adai
surez_june
Thanks Adai. Would you recommend any other means of monitoring syncmirror aggregate status?
