Netapp Work Flow automation
VKS
Hi Guys,
I am new to Work Flow Automation (WFA). I would like to automate my day to day task and mostly the monitoring task. can we do using WFA and how to start WFA from the scratch.
regards
Vinay
2 REPLIES 2
hariprak
Hi,
OnCommand Workflow Automation (WFA) is a software solution that helps to automate storage management tasks, such as provisioning, migration, decommissioning, and cloning storage.
You can use WFA to build workflows to complete tasks specified by your processes. WFA supports both clustered Data ONTAP and Data ONTAP operating in 7-Mode.
For WFA installation and setup guide you can refer the below link,
https://library.netapp.com/ecm/ecm_get_file/ECMP1644817
For WFA workflow developer's guide you can refer the below link,
https://library.netapp.com/ecm/ecm_get_file/ECMP1644818
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
abhit
Hi:
Also there are lots of workflows available at:
http://automationstore.netapp.com/pack-list.shtml.
As a first step, you can check if any of these are directly usable.
Regards
Abhi
