Running job will not abort
SALVATORE_PUGLISI
Hey guys
Does anyone know how to force the abort of an job? I have a job that hung for more than 10 days, last week i cancelled the running job but now it's still on "cancelling".
I also tried to abort the job over the command line with
dfbm job abort 197850
the result is
Error: Job 197850 is already being aborted.
Since 6 days I have this message, actually I cannot take a backup of the desired dataset as the dataset waits for the job to finish.
Can anyone help me?
Regards.
sal
1 ACCEPTED SOLUTION
arunchak
Hi,
you can try "dfm service stop -k" and then start the service "dfm service start". See if this frees up your dataset.
Thanks,
  Arun
4 REPLIES 4
arunchak
Hi,
Thanks,
  Arun
SALVATORE_PUGLISI
Thanks Arun,
you were right. In this case the easier way was the solution.
Thanks
Sal
adaikkap
If you are using a linux box you could go a ps -eaf | grep -i dfpm and find the job id and do a kill -9 instead of doing a service stop.
Regards
adai
Nat
and if you are using Windows, after identified job number (GUI or dfpm job list -v jobs-running), then start the Task Manager, "Processes" tab, make sure you "show processes from all users", View>Select column... , check the "Command Line" column, you must now see the ...\dfpm.exe" job run job_id, the you can end this one only.
