Unable to get system counter info for sys_avg_latency when using apitest.exe
agnesj
Hi,
I am trying to get the "sys_avg_latency" counter-name for object-type "system" using apitest and I am unable to get the counter values.  I am able to get the
counter values for "avg_processor_busy".  IS there an extra parameter I should put in the input xml? Or is this counter not available thru the DFM?  Please advise.
The input xml (perf3.xml):
<perf-get-counter-data>
<instance-counter-info>
<counter-info>
<perf-object-counter>
<counter-name>sys_avg_latency</counter-name>
<object-type>system</object-type>
</perf-object-counter>
</counter-info>
<object-name-or-id>172.17.39.164</object-name-or-id>
</instance-counter-info>
</perf-get-counter-data>
COMMAND:
apitest.exe -I -t dfm 172.17.38.144 root Netapp123 < perf3.xml
<results status="passed">
        <perf-instances>
                <perf-instance-counter-data>
                        <instance-name>system</instance-name>
                        <object-id>222</object-id>
                        <counters>
                                <perf-counter-data>
                                        <label-names/>
                                        <unit>millisec</unit>
                                        <counter-data/>
                                </perf-counter-data>
                        </counters>
                </perf-instance-counter-data>
        </perf-instances>
</results>
4 REPLIES 4
rle
NetApp Alumni
Hi Agnes -
I would use perf-object-counter-list-info to obtain a valid list of counters for the system object.
Regards,
   - Rick -
agnesj
Hi,
Yes, I have tried it and sample output does include sys_avg_latency as a valid counter.  The input.xml is as follows:
<perf-object-counter-list-info>
<object-name>system</object-name>
</perf-object-counter-list-info>
Here is a snippet of the output  and attached is the entire output from getting perf-object-counter-list-info for "system":
               <perf-counter>
                       <desc>Average latency for all operations in the system in milliseconds</desc>
                       <name>sys_avg_latency</name>
                       <properties>average</properties>
                       <is-display>true</is-display>
                       <privilege-level>basic</privilege-level>
                       <base-counter>total_ops</base-counter>
               </perf-counter>
Please advise if there something I need to add to the input.xml to get the counter values for "sys_avg_latency"
aashray
Hi Agnes,
Which version of DFM are you using?
I am using DFM 5.0.1.
Calling perf-object-counter-list-info for system indicates that there is no  sys_avg_latency counter. Hence it is not a valid counter.
aashray
The sys_avg_latency is dependent on total_ops.
Try running this as input to your DFM.
<perf-get-counter-dependents>
    <counters>
        <counter-description></counter-description>
        <counter-name>total_ops</counter-name>
        <is-calculated-stats></is-calculated-stats>
    </counters>
  </perf-get-counter-dependents>
The output i got was :
<results status='passed'>
                    <dependent-counters>
<is-calculated-stats>false</is-calculated-stats>
                    </dependent-counters>
                    <base-counters/>
                    <reports/>
                    <views/>
                    <threshold-templates/>
                    <thresholds/>
          </results>
