Active IQ and AutoSupport Discussions
ACP partial connectivity (module goes inactive or offline)
scottgelb
I have noticed at several customers with different ONTAP versions where ACP stops working on some modules.  Installations that were at Full Connectivity, no changes made then when going back onsite at a future date to check systems or add shelves later, we often find "partial connectivity" and a module that has gone inactive.
In most cases, turning off and on acp fixes the issue.  In some of the cases it does not and we have to pull and reseat the IOM module to get full connectivity back. ACP isn't required for a system but it isn't encouraging having to fix things that break without changes made.
Anyone else seeing this?
7 REPLIES 7
scottgelb
This is even with the latest ACP firmware and IOM firmware
DRUMDUDESAN
Scott,
I am seeing the exact same issue now as I was preparing for Data OnTap upgrade and checking the logs. I cannot find any good information on it either. Pulling the IOM and re-seating is odd and I bet when you go back it will be there again. I think I may open a ticket. If I find out anything I will pots back.
Alternate Control Path:  Enabled
Ethernet Interface:      e0a
ACP Status:              Active
ACP IP Address:          192.168.0.129
ACP Domain:              192.168.0.129
ACP Netmask:             255.255.252.0
ACP Connectivity Status: Partial Connectivity
Shelf Module      Reset Cnt    IP Address      FW Version   Module Type  Status
3d.00.A           000          192.168.1.181   01.15        IOM3         not-responding (last contact at: "Sat Oct 27 18:08:17 EDT 2012")
3d.00.B           000          192.168.1.177   01.15        IOM3         not-responding (last contact at: "Sat Oct 27 18:11:15 EDT 2012")
3d.01.A           000          192.168.1.175   01.15        IOM3         not-responding (last contact at: "Sat Oct 27 18:08:15 EDT 2012")
3d.01.B           000          192.168.1.178   01.15        IOM3         not-responding (last contact at: "Sat Oct 27 18:08:12 EDT 2012")
scottgelb
I'm seeing it less lately... and almost every time disabling and enabling ACP fixes it.. the not-responding is the same message as well that I see when it happens.
DRUMDUDESAN
Hi,
I checked my hosts and RC files for invalid entries; it looked good. I updated to the shelf firmware awhile back from 131 to 144. I got alerted from AutoSupport to update ACP this month so maybe the fix is in it. I have now updated the ACP firmware from 01.15 to 01.31. I will monitor this to see how it goes.
Shelf   0: IOM3  Firmware rev. IOM3 A: 0144 IOM3 B: 0144
Shelf   1: IOM3  Firmware rev. IOM3 A: 0144 IOM3 B: 0144
ACP Status:              Active
ACP IP Address:          192.168.0.254
ACP Domain:              192.168.0.0
ACP Connectivity Status: Full Connectivity
3d.00.A           000          192.168.1.181   01.31        IOM3         active
3d.00.B           000          192.168.1.177   01.31        IOM3         active
3d.01.A           000          192.168.1.175   01.31        IOM3         active
3d.01.B           000          192.168.1.178   01.31        IOM3         active
CCOLEMAN_
Jeff, what's the IP of the SP?
Remember the ACP address can't be same same first 2 octets as SP (192.168.x.x)
DRUMDUDESAN
Hi,
If we are on the same page. This is a v3140a. So you are referring to RLM. Which are all 10.x.x.x. I think newer models use the term SP?
With the new ACP-firmware it is still working so far.
Cheers
Jeff
CCOLEMAN_
Yea RLM, BMC, and SP are all similar, but SP is the latest and greatest.
I just wanted to throw that out there just in case.
Glad it's still working for you!
-Chris
