Active IQ and AutoSupport Discussions
Initinialize disks controller 2 on FAS2240-4 ontap 8.2.5 7-mode
torres91
Hi All,
I have a question. Actually, i'm working with a FAS2240-4 with ontap 7-mode with a DS4246 disk shelf. The Controller B was down by a insoncistence aggr0 and WALF.  We able to rescue and recovery the data from aggr0.
At the moment, the controller A is serving  production data (LUNs) to VMWare hosts.
We need to reuse the controller B and i'm searching NetApp documentation and found the use of boot menu --> op 4 " Clean configuration and initialize all disks".   Before to perform this activity, I need to confirm that this operation only clean and initialize owned disks by controller B and the disks owneb by controller A will be secures.
The disks owned by controller B are in DS4246 (all 24 disks), and disks from controller B are inside of FAS2240-4 chasis.
Thanks in advance
1 ACCEPTED SOLUTION
AlexDawson
Hi there! For 7 mode, yes, boot to maintenance mode first on controller B, and run "sysconfig -a", "disk show" and "disk show -a" and ensure that the ownership of the disks is correct, and at that point it is fine to use option 4 from the special boot menu and be confident it will only touch the disks it owns.
Hope this helps!
2 REPLIES 2
AlexDawson
Hope this helps!
torres91
Thanks Alex for your answer. I have an additionaly question, when I come back the second controller, and I need to perform again the cluster or HA configuration, I need a maintenance window for controller A? Or this step can i do it on line?
