Active IQ and AutoSupport Discussions
My autosupport and flash cache
regis_carlier
Hi,
I have several systems with flash cache . The configurations are fine ( options, licence, sysconfig,...) and i can see the cache usage with stats.
My autosupport reports a Risk ..... Saying That pamII module is not configured....
Did i miss something ? Is There à problem with my conf ? Or is it à problem with autosupport ?
TIA
Régis
7 REPLIES 7
kumaraysun
Hi
You can check the status of the PAM module with sysconfig output.
once you see the PAM is installed in the output make sure license is applied (licese command) and options "flexscale.enable" is set to ON.
Kumaresan
regis_carlier
Hi ,
thanks but
the card is seen as enable , the license is installed and options are configured .
I don't know why I've got this error in myautosupport.
Regis/
jakob_bena
hello,
which ontap version did you use, and which system?
as i know, there are some problems with ontap8.x and flash cash / pam.
with ontap 8.1 autosupport only works with https, and there we can only use the option autosupport.noteto
regards
regis_carlier
Hi ,
Thanks,
I use Ontap 8.1RC2 .... and autosupport transport is configured with mail .... 😞
I'll modify autosupport options to use https .
Regis/
jakob_bena
you get only a simple massege if you add your support email to these noteto option. only for the new systems fas2240 for properly.
and for the systems fas3210 and fas3140 they have an issue with their memory. there will the flash cash card not work.
regis_carlier
Thanks.
waiting for 8.1 final release 🙂
radek_kubka
