Active IQ and AutoSupport Discussions
issue with cf giveback on netapp 3140
Afridi
Hi,
     we have 3140 and one of controller have taken over . after checking cf status it says that it is ready to giveback but when i issue "cf giveback" it says that "Failed Disk 1d.20 should be removed before the giveback command is invoked" followed by "Fail over monitor: disk Check: giveback cancelled due to active state"
now i am new to netapp so i am searching on internet that how to chnage the failed disk and initially i found to blink the disk. as physically i saw some 7 disk with amber light but " vol status -f " shows only 2 x failed disks. but when i try to blink_on 1d.20 so i dont see any blinking on shelves.
please guide
Regards
3 REPLIES 3
amans
Hello Afridi,
Did you run the command in advanced mode?
Example:
node> priv set advanced
node*> blink_on 1d.20
You can also try node*> led_on 1d.20
Reference: https://kb.netapp.com/Advice_and_Troubleshooting/Data_Storage_Systems/FAS_Systems/How_to_identify_a_failed_disk_prior_to_replacement
Regards,
Aman
Afridi
Thank you for reply
Yes i did but it is not working . even i tried to find it in output of disk show commnad but i didn't see it . there are other disks which are shown and "Failed" is displayed in front of it  but not this one and blink_on works very well for other Fialed disk
regards
bretta
I would highly recommend opening a case with support.
