Data Protection
SnapManager Migration Guide to SnapCenter
TMADOCTHOMAS
There is a SnapManager Migration Guide available for SnapCenter 1.1:
https://library.netapp.com/ecm/ecm_download_file/ECMLP2440302
However, i cannot find an updated one for version 4.0. All I can find is the "Importing Data from SnapManager to SnapCenter" guide which just describes importing backups archived using SnapVault (we use SnapMirror so this doesn't apply to us).
Any suggestions? Does anyone know if a 4.0 version is on the way? Does the 1.1 procedure still work in 4.0?
1 ACCEPTED SOLUTION
AshishGupta
This is actually covered in SnapCenter 4.0 under a different guide name: Importing Data from SnapManager to SnapCenter
Refer guide here:
https://library.netapp.com/ecm/ecm_download_file/ECMLP2840890
For VMware workload, this is covered under heading "Migrating VSC hosts" as part of the "Installation and Setup Guide"
Refer guide here:
https://library.netapp.com/ecm/ecm_download_file/ECMLP2840879
There is also an import utility for migrating VSC (SMVI) workload to SCV and VSC released called: NetApp Import Utility for SnapCenter and Virtual Storage Console
Link: https://mysupport.netapp.com/tools/info/ECMLP2840096I.html?productID=62135&pcfContentID=ECMLP2840096
SCV-VSC-Import-README.pdf covers all the necessary details bundled along with the zip file.
2 REPLIES 2
AshishGupta
Refer guide here:
Refer guide here:
TMADOCTHOMAS
Excellent! Thank you very much.
