Data Protection
Difference between SnapProtect (SP) and NetApp Syncsort Integrated Backup (NSB)?
csoxcel10
Would appreciate if you could help me with understanding the differences between SnapProtect (SP) and NetApp Syncsort Integrated Backup (NSB)? where SP and NSB can be the best fit?
2 REPLIES 2
peter_lehmann
Here is some "light reading" on these two products:
SnapProtect Technical Report
http://media.netapp.com/documents/tr-3920.pdf
Syncsort NSB BLOG by Scott Gelb
http://communities.netapp.com/people/scottgelb/blog/2011/03/28/netapp-syncsort-integrated-backup-nsb
Hope this helps,
Peter
scottgelb
A basic rule of thumb...
If the data you are protecting resides on NetApp storage, then SnapProtect (Simpana) might be a good fit.
If the data you are protecting does NOT reside on NetApp storage (and you want to protect it on NetApp storage), then NSB might be a good fit.
