Data Protection
Edit a schedule in v4.3 does not work.
VOLVOMAGNUS
When i click edit on a schedule the "Action" field is empty and the "Save" button is dimmed.
If i click on the "Action" field nothing happens.
So basically I cannnot edit schedules. i have to delete and create new which is annoying.
2 REPLIES 2
kris_boeckx
Hi,
I have the same problem. The workarround  is to re-select the "configuration", then select the correct "Action" and "Policy" and click "save"
This is very annoying so please fix this issue
kris_boeckx
Hi,
We opened a case with Netapp. Bug ID is: 1006668
see http://mysupport.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=1006668
We have to wait until they release a new version.
Greetings,
Kris Boeckx.
