Data Protection
Exit code issue when using a shell script to quiesce a MySQL database
jcbettinelli
Hello,
I'm trying to setup up SnapCreator for MySQL for a customer.
At first, we tried the integrated plug-in, but it seems that we're facing a net::mysql issue, as the script doesn't work more than once when the agent is fresh started.
So I found a script to quiesce all databases with mysql commands.
#!/bin/bash
#set -x
#set $(date)
#str_Tag=$(date +%A);
MYSQL_PWD="toto"
DBASELIST=`mktemp`
mysqlshow -p$MYSQL_PWD | awk '{print $2}' | grep -v Databases | sort >$DBASELIST
# Flush of databases
for x in `cat $DBASELIST`; do
        echo $x
        mysql -u root -p$MYSQL_PWD $x -e "flush tables with read lock" -v
        mysql -u root -p$MYSQL_PWD $x -e "flush logs" -v
done;
My issue is that when the backup runs, the result of the script that is sent to the server is -1, which the server interprets as a no-go for the snapshot.
########## APPLICATION QUIESCE COMMANDS ##########
[2013-11-08 16:11:26,091] INFO: [dbmasterbkp:9090 (4.0.0.1)] Executing Application quiesce command [/home/pentaadmin/netapp/quiesce.sh] on dbmasterbkp
[2013-11-08 16:11:26,091] DEBUG: [dbmasterbkp:9090 (4.0.0.1)] Executing command [/home/pentaadmin/netapp/quiesce.sh]
[2013-11-08 16:11:26,091] TRACE: Command [/home/pentaadmin/netapp/quiesce.sh] finished with
exit code: [-1]
stdout: []
stderr: []
[2013-11-08 16:11:26,092] ERROR: [dbmasterbkp:9090 (4.0.0.1)] Command [/home/pentaadmin/netapp/quiesce.sh] failed with return code [-1] and message []
########## Application not defined. Skipping Unquiesce task ##########
########## Snap Creator Framework 4.0p1 failed ##########
########## PRE EXIT COMMANDS ##########
[2013-11-08 16:11:26,360] INFO: [dbmasterbkp:9090 (4.0.0.1)] Executing Pre Exit command [/home/pentaadmin/netapp/unquiesce.sh] on dbmasterbkp
[2013-11-08 16:11:26,360] DEBUG: [dbmasterbkp:9090 (4.0.0.1)] Executing command [/home/pentaadmin/netapp/unquiesce.sh]
[2013-11-08 16:11:26,360] TRACE: Command [/home/pentaadmin/netapp/unquiesce.sh] finished with
exit code: [-1]
stdout: []
stderr: []
[2013-11-08 16:11:26,360] ERROR: [dbmasterbkp:9090 (4.0.0.1)] Command [/home/pentaadmin/netapp/unquiesce.sh] failed with return code [-1] and message []
The script runs well, and if I run it manually, and then I enter >echo $?, the exit code comes at 0.
Do I need to add something at the end of the script ?
Thank you in advance for your help,
JC
1 REPLY 1
sivar
You may want to supply your own exit code within the script.
There is a good amount of discussion here.
http://stackoverflow.com/questions/64786/error-handling-in-bash
I will also test your code in the lab and update here with my findings.
