Data Protection
ONTAP 9 Modifying SnapVault Source Volume without baseline transfer
tyrone_owen_1
Hi,
In 7-mode you could modify the SV source volume without incurring a full baseline transfer: https://kb.netapp.com/app/answers/answer_view/a_id/1034855/~/how-to-move-a-snapvault-or-snapmirror-primary-from-one-volume-to-another
Has anyone completed this activity in ONTAP 9.3+?
Cheers
1 ACCEPTED SOLUTION
tyrone_owen_1
Thanks for the reply.
The process for SnapVault is slightly different to the one in the article:
  • Update SnapVault between A -> C
  • Break SnapVault between A -> C (stop further updates)
  • Update the SnapMirror relationships A -> B (transferring the SV baseline snap)
  • Break the snapmirror relationship between A -> B
  • Delete the SV relationship between A -> C (you don't seem to be able to set up a second SV relationship on the destination vol)
  • Create the SV relationship between B -> C
  • Resync the SV relationship between B -> C
Cheers
2 REPLIES 2
GidonMarcus
Hi
the correct article for Cdot is in:
https://kb.netapp.com/app/answers/answer_view/a_id/1029919
Gidi Marcus (Linkedin) - Storage and Microsoft technologies consultant - Hydro IT LTD - UK
tyrone_owen_1
Cheers
