The NetApp Community will be placed into Read-Only mode soon, as we prepare to move to a new platform.
Click to learn more.
Data Protection
Oracle 9 backup using oraback.sh script
jntballard
Hi Keith,
I found the oraback.sh script that looks like has been used with older versions of SnapCreator 3.1/3.2.  for backing up older versions of Oracle.  Unfortunately this client has two DBs that are still on Oracle 9.X.
Can this script be used with SC 3.4? I am assuming when I create the configuration for the profile I would select "NONE", and change the following in the config:
  • PRE_APP_QUIESCE_CMD01=/path/to/oraback.sh begin online <SID>
  • POST_APP_QUIESCE_CMD01=/path/to/oraback.sh end online <SID>
And add the following variable (noticed it is referenced in the comments, but not anywhere else in the config):
  • PRE_EXIT_CMD01=/path/to/oraback.sh end online <SID>
This will put the DB in/out of hot-backup mode, can this handle the archive log switch too and log rotation?
Thanks,
Jerry
2 REPLIES 2
ktenzer
Yep it works with 3.4.0
Here is info follow examples for 3.2.x that is what you would do
http://communities.netapp.com/docs/DOC-5882
Regards,
Keith
PUKKA_XUJIE
can't access
