Data Protection
PRE_MOUNT_CMD01 and PRE_UMOUNT_CMD01 settings deleted when config saved in GUI
pilkar
New PRE_MOUNT/PRE_UMOUNT cmds in 4.1.2 have problems when saving configuration in GUI.
When I define these commands by editting config file, for example as show below
#     Pre Commands        #
PRE_UMOUNT_CMD01=SERVER:echo PRE_UMOUNT_CMD01
PRE_MOUNT_CMD01=SERVER:echo PRE_UMOUNT_CMD01
Then I open the config in GUI to run some actoin or edit some other parameters... And save the config in GUI, settings of PRE_MOUNT and PRE_UMOUNT cmds are lost:
#     Pre Commands        #
PRE_UMOUNT_CMD01=
PRE_MOUNT_CMD01=
In case you have mode CMDs, only CMD01 is lost:
#     Pre Commands        #
PRE_UMOUNT_CMD01=SERVER:echo "CMD01"
PRE_UMOUNT_CMD02=SERVER:echo "CMD02"
PRE_UMOUNT_CMD03=SERVER:echo "CMD03"
PRE_MOUNT_CMD01=SERVER:echo "CMD01"
PRE_MOUNT_CMD02=SERVER:echo "CMD02"
after saving in GUI:
#     Pre Commands        #
PRE_UMOUNT_CMD01=null
PRE_MOUNT_CMD01=null
Does anyone have the same troubles?
BR,
Rostislav
1 ACCEPTED SOLUTION
spinks
That is not the expected behavior.
Please open a support case on this.
Thanks!
John
1 REPLY 1
spinks
Thanks!
John
