Data Protection
Problem with Operations Manager events
magnus_nyvall
Hi!
I just installed Snapcreator 3.4.0 on a Windows host for the first time.
Did it on Linux hosts before where it worked just fine.
IIt works well on the Windows host to until i wanted to get events to the OM server.
I entered the following in the config file:
### Operations Manager Settings ###
OM_HOST=segotn878
OM_USER=sapscadm
OM_PWD=sapdb201
OM_PORT=8080
OM_EVENT_GENERATE=Y
I also tested to login to the DFM server on that windows host with Internet Explorer and it worked just fine.
This is the result at the end of an execution:
########## NetApp Snap Creator Framework finished successfully ##########
[Tue Nov 22 11:37:27 2011] INFO: INFO: NetApp Snap Creator Framework finished successfully ( Action: snap )
[Tue Nov 22 11:37:27 2011] ERROR: validation of target segotn878 failed [
syntax error at line 1, column 49, byte 49:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
at /<C:\Program Files\NetApp\NetApp_Snap_Creator_Framework\scServer3.4.0\snapcreator.exe>XML/Parser.pm line 187
<html><head>
Any suggestions to what i am missing here?
Are there some additional requirements for a Windows host?
Regards Magnus
2 REPLIES 2
magnus_nyvall
I solved it.
It was the wrong port. 8088 worked.
But now the question arised about using https communication to OM server.
Is that possible?
I found no option for protocol.
Regards Magnus
ktenzer
Certainly you can use HTTPS. Set OM_PORT=8488 and ensure that port is open from scServer to DFM server
Regards,
Keith
