Data Protection
Removing a Drive letter of a Mounted LUN will disturb the production??
NAYABRASOOL
Hi All,
Last week as a part of LUN MIGRATION activity i have added a LUN and assigned a drive letter to it and for the same LUN i have created a MOUNT POINT as well and its been added to CLUSTER and was servering data , Now the thing is can i remove the drive letter alone of that LUN. Please refer to the screen shot which the SVUSDB05LUNBKP has both drive letter and mount Point , Now i need to remove the Drive Letter  ' W '. Please advise if this needs any downtime else i can do it online.
Thanks,
Nayab
1 ACCEPTED SOLUTION
nigelg1965
Assuming there are no files open on it, you should be able to remove it without cause any problems.
I'd do it in Snapdrive if I was you, you may need to use force disconnect.
I've done this many times before without any issues.
2 REPLIES 2
nigelg1965
NAYABRASOOL
What if i have transactions happening to that LUN will that effect as we have mentioned both MOUNT POINT and Drive letter in the CLUSTER FAILOVER MANAGER. Please find the screen shot.
Sorry , We are not using SNAP DRIVE at this point . Please advise accordingly.
