Data Protection
SC4 and volume validation with db2.
magnus_nyvall
Hi when i set VALIDATE_VOLUMES=DATA it fails and want me to include the log volume.
This is not how it behaves with 3.6.
Has the options for this changed?
Also this option cant be edited in the gui.
The same for the OnCommand/DFM folder. The dataset bit cannot be edited in the gui.
Regards Magnus
2 REPLIES 2
ktenzer
You shouldn't need the log volume we only validate data files not logs, however if you have data files elsewhere (maybe temp data files or some other data files) it will fail.
Still if it worked in SC 3.6 it should work in 4.0 but I do know there was a bug in this code in 3.6 when multiple volumes were involved where it wasnt discovering things properly but that we fixed in 4.0.
If this is urgent I would open an NGS support case otherwise we will look into this. Can you please send logs and your config (without passwords)? Make sure you set the option LOG_TRACE_ENABLE=Y and then run backup to generate error and send those debug logs.
Regards,
Keith
magnus_nyvall
Here is output fom sc3.6p1 and 4.0 runned on the same database host.
Here is ouput from SC4:
########## Detecting Data ONTAP mode for segotx608 ##########
########## Agent validation ##########
[2013-06-17 13:26:03,513] INFO: Agent validation completed successfuly for agent 131.97.178.132:9090
########## Plugin validation ##########
[2013-06-17 13:26:03,529] INFO: Plugin validation completed successfuly for plugin db2
########## PRE APPLICATION QUIESCE COMMANDS ##########
[2013-06-17 13:26:03,529] INFO: Pre application quiesce commands are not defined
########## PRE APPLICATION QUIESCE COMMANDS FINISHED SUCCESSFULLY  ##########
[2013-06-17 13:26:03,529] INFO: Application auto discovery is not enabled skipping .
########## Volume Validation for plugin db2 ##########
[2013-06-17 13:26:12,826] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovering databases
[2013-06-17 13:26:12,826] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovering database S5E
[2013-06-17 13:26:12,826] INFO: [131.97.178.132:9090 (4.0.0.1)] Retrieving database path used for database S5E
[2013-06-17 13:26:12,826] INFO: [131.97.178.132:9090 (4.0.0.1)] Retrieving database directory for database S5E
[2013-06-17 13:26:12,826] INFO: [131.97.178.132:9090 (4.0.0.1)] Retrieving tablespaces for database S5E
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Retrieving tablespace containers for database S5E
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000000/C0000000.CAT
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000000/C0000001.CAT
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000000/C0000002.CAT
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000000/C0000003.CAT
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000000/C0000004.CAT
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000000/C0000005.CAT
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000000/C0000006.CAT
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000000/C0000007.CAT
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000000/C0000008.CAT
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000000/C0000009.CAT
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000001/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000001/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000001/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000001/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000001/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000001/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000001/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000001/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000001/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000001/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000010/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000010/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000010/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000010/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000010/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000010/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000010/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000010/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000010/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000010/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000011/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000011/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000011/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000011/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000011/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000011/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000011/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000011/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000011/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000011/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000012/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000012/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000012/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000012/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000012/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000012/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000012/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000012/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000012/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000012/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000013/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000013/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000013/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000013/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000013/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000013/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000013/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000013/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000013/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000013/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000014/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000014/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000014/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000014/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000014/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000014/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000014/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000014/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000014/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000014/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000015/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000015/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000015/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000015/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000015/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000015/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000015/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000015/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000015/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000015/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000016/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000016/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000016/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000016/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000016/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000016/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000016/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000016/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000016/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000016/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000017/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000017/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000017/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000017/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000017/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000017/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000017/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000017/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000017/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000017/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000018/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000018/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000018/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000018/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000018/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000018/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000018/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000018/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000018/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000018/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000019/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000019/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000019/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000019/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000019/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000019/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000019/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000019/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000019/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000019/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000002/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000002/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000002/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000002/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000002/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000002/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000002/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000002/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000002/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000002/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000020/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000020/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000020/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000020/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000020/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000020/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000020/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000020/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000020/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000020/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000021/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000021/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000021/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000021/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000021/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000021/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000021/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000021/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000021/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000021/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000022/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000022/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000022/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000022/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000022/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000022/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000022/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000022/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000022/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000022/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000023/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000023/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000023/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000023/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000023/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000023/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000023/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000023/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000023/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000023/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000024/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000024/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000024/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000024/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000024/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000024/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000024/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000024/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000024/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000024/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000025/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000025/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000025/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000025/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000025/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000025/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000025/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000025/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000025/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000025/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000026/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000026/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000026/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000026/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000026/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000026/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000026/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000026/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000026/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000026/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000027/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000027/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000027/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000027/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000027/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000027/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000027/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000027/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000027/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000027/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000028/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000028/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000028/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000028/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000028/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000028/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000028/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000028/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000028/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000028/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000029/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000029/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000029/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000029/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000029/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000029/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000029/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000029/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000029/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000029/C0000009.LRG
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000003/C0000000.TMP] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000003/C0000001.TMP] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000003/C0000002.TMP] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000003/C0000003.TMP] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000003/C0000004.TMP] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000003/C0000005.TMP] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000003/C0000006.TMP] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000003/C0000007.TMP] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000003/C0000008.TMP] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000003/C0000009.TMP] of type [Path]
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000030/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000030/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000030/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000030/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000030/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000030/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000030/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000030/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000030/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000030/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000031/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000031/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000031/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000031/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000031/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000031/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000031/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000031/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000031/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000031/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000032/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000032/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000032/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000032/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000032/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000032/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000032/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000032/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000032/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000032/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000033/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000033/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000033/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000033/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000033/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000033/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000033/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000033/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000033/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000033/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000034/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000034/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000034/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000034/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000034/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000034/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000034/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000034/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000034/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000034/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000035/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000035/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000035/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000035/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000035/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000035/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000035/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000035/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000035/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000035/C0000009.LRG
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000004/C0000000.UTM] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000004/C0000001.UTM] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000004/C0000002.UTM] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000004/C0000003.UTM] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000004/C0000004.UTM] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000004/C0000005.UTM] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000004/C0000006.UTM] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000004/C0000007.UTM] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000004/C0000008.UTM] of type [Path]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignored [/db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000004/C0000009.UTM] of type [Path]
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000005/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000005/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000005/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000005/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000005/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000005/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000005/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000005/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000005/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000005/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000006/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000006/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000006/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000006/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000006/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000006/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000006/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000006/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000006/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000006/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000007/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000007/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000007/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000007/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000007/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000007/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000007/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000007/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000007/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000007/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000008/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000008/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000008/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000008/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000008/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000008/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000008/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000008/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000008/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000008/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000009/C0000000.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000009/C0000001.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000009/C0000002.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000009/C0000003.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000009/C0000004.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000009/C0000005.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000009/C0000006.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000009/C0000007.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000009/C0000008.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000009/C0000009.LRG
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Retrieving database configuration for database S5E
[2013-06-17 13:26:12,841] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovered configuration parameter [Path to log files] / [/db2/S5E/log_dir/NODE0000/]
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignoring database configuration parameter [OVERFLOWLOGPATH] / []
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignoring database configuration parameter [NEWLOGPATH] / []
[2013-06-17 13:26:12,841] WARN: [131.97.178.132:9090 (4.0.0.1)] Ignoring database configuration parameter [MIRRORLOGPATH] / []
[2013-06-17 13:26:12,857] INFO: [131.97.178.132:9090 (4.0.0.1)] Discovering databases finished successfully
[2013-06-17 13:26:12,857] ERROR: SCF-00065: Volume [[got608v001]] on [segotx608] is not included in the config file.
########## Snap Creator Framework 4.0.0 failed ##########
[2013-06-17 13:26:12,857] INFO: Pre Exit commands are not defined. Skipping !
Here is ouput from SC3.6p1:
[Mon Jun 17 09:42:01 2013] INFO: Logfile timestamp: 20130617094201
[Mon Jun 17 09:42:01 2013] INFO: Plugin validation skipped for db2, no plugin parameters file found or no parameters set
[Mon Jun 17 09:42:01 2013] INFO: Removing log r3s5e_db2.out.20130612094201.log
[Mon Jun 17 09:42:01 2013] INFO: Removing log r3s5e_db2.debug.20130612094201.log
[Mon Jun 17 09:42:01 2013] INFO: Removing log r3s5e_db2.stderr.20130612094201.log
########## Parsing Environment Parameters ##########
[Mon Jun 17 09:42:01 2013] INFO: No commands defined
[Mon Jun 17 09:42:01 2013] INFO: Validating volumes
[Mon Jun 17 09:42:01 2013] INFO: Discovering databases
[Mon Jun 17 09:42:01 2013] INFO: Discovering database S5E
[Mon Jun 17 09:42:01 2013] INFO: Retrieving database path used for database S5E
[Mon Jun 17 09:42:02 2013] INFO: Retrieving database directory for database S5E
[Mon Jun 17 09:42:04 2013] INFO: Retrieving tablespaces for database S5E
[Mon Jun 17 09:42:05 2013] INFO: Retrieving tablespace containers for database S5E
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000000/C0000000.CAT
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000000/C0000001.CAT
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000000/C0000002.CAT
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000000/C0000003.CAT
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000000/C0000004.CAT
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000000/C0000005.CAT
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000000/C0000006.CAT
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000000/C0000007.CAT
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000000/C0000008.CAT
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000000/C0000009.CAT
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000001/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000001/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000001/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000001/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000001/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000001/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000001/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000001/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000001/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000001/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000010/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000010/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000010/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000010/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000010/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000010/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000010/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000010/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000010/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000010/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000011/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000011/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000011/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000011/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000011/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000011/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000011/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000011/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000011/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000011/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000012/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000012/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000012/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000012/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000012/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000012/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000012/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000012/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000012/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000012/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000013/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000013/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000013/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000013/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000013/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000013/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000013/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000013/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000013/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000013/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000014/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000014/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000014/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000014/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000014/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000014/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000014/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000014/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000014/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000014/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000015/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000015/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000015/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000015/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000015/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000015/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000015/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000015/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000015/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000015/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000016/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000016/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000016/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000016/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000016/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000016/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000016/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000016/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000016/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000016/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000017/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000017/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000017/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000017/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000017/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000017/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000017/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000017/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000017/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000017/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000018/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000018/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000018/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000018/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000018/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000018/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000018/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000018/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000018/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000018/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000019/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000019/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000019/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000019/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000019/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000019/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000019/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000019/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000019/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000019/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000002/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000002/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000002/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000002/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000002/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000002/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000002/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000002/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000002/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000002/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000020/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000020/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000020/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000020/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000020/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000020/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000020/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000020/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000020/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000020/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000021/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000021/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000021/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000021/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000021/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000021/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000021/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000021/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000021/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000021/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000022/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000022/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000022/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000022/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000022/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000022/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000022/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000022/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000022/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000022/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000023/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000023/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000023/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000023/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000023/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000023/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000023/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000023/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000023/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000023/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000024/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000024/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000024/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000024/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000024/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000024/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000024/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000024/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000024/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000024/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000025/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000025/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000025/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000025/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000025/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000025/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000025/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000025/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000025/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000025/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000026/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000026/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000026/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000026/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000026/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000026/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000026/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000026/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000026/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000026/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000027/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000027/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000027/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000027/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000027/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000027/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000027/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000027/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000027/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000027/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000028/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000028/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000028/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000028/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000028/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000028/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000028/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000028/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000028/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000028/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000029/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000029/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000029/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000029/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000029/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000029/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000029/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000029/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000029/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000029/C0000009.LRG
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000003/C0000000.TMP] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000003/C0000001.TMP] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000003/C0000002.TMP] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000003/C0000003.TMP] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000003/C0000004.TMP] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000003/C0000005.TMP] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000003/C0000006.TMP] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000003/C0000007.TMP] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000003/C0000008.TMP] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000003/C0000009.TMP] of type [Path]
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000030/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000030/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000030/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000030/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000030/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000030/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000030/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000030/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000030/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000030/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000031/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000031/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000031/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000031/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000031/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000031/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000031/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000031/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000031/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000031/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000032/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000032/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000032/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000032/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000032/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000032/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000032/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000032/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000032/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000032/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000033/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000033/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000033/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000033/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000033/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000033/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000033/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000033/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000033/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000033/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000034/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000034/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000034/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000034/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000034/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000034/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000034/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000034/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000034/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000034/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000035/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000035/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000035/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000035/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000035/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000035/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000035/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000035/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000035/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000035/C0000009.LRG
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000004/C0000000.UTM] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000004/C0000001.UTM] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000004/C0000002.UTM] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000004/C0000003.UTM] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000004/C0000004.UTM] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000004/C0000005.UTM] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000004/C0000006.UTM] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000004/C0000007.UTM] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000004/C0000008.UTM] of type [Path]
[Mon Jun 17 09:42:08 2013] WARN: Ignored [/db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000004/C0000009.UTM] of type [Path]
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000005/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000005/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000005/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000005/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000005/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000005/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000005/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000005/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000005/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000005/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000006/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000006/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000006/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000006/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000006/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000006/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000006/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000006/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000006/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000006/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000007/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000007/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000007/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000007/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000007/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000007/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000007/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000007/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000007/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000007/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000008/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000008/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000008/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000008/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000008/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000008/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000008/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000008/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000008/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000008/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata1/db2s5e/NODE0000/S5E/T0000009/C0000000.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata2/db2s5e/NODE0000/S5E/T0000009/C0000001.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata3/db2s5e/NODE0000/S5E/T0000009/C0000002.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata4/db2s5e/NODE0000/S5E/T0000009/C0000003.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata5/db2s5e/NODE0000/S5E/T0000009/C0000004.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata6/db2s5e/NODE0000/S5E/T0000009/C0000005.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata7/db2s5e/NODE0000/S5E/T0000009/C0000006.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata8/db2s5e/NODE0000/S5E/T0000009/C0000007.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata9/db2s5e/NODE0000/S5E/T0000009/C0000008.LRG
[Mon Jun 17 09:42:08 2013] INFO: Discovered file /db2/S5E/sapdata10/db2s5e/NODE0000/S5E/T0000009/C0000009.LRG
[Mon Jun 17 09:42:08 2013] INFO: Retrieving database configuration for database S5E
[Mon Jun 17 09:42:09 2013] INFO: Discovered configuration parameter [Path to log files] / [/db2/S5E/log_dir/NODE0000/]
[Mon Jun 17 09:42:09 2013] WARN: Ignoring database configuration parameter [OVERFLOWLOGPATH] / []
[Mon Jun 17 09:42:09 2013] WARN: Ignoring database configuration parameter [NEWLOGPATH] / []
[Mon Jun 17 09:42:09 2013] WARN: Ignoring database configuration parameter [MIRRORLOGPATH] / []
[Mon Jun 17 09:42:10 2013] INFO: Discovering databases finished successfully
[Mon Jun 17 09:42:11 2013] INFO: validating group: DATA
[Mon Jun 17 09:42:11 2013] INFO: Validation finished successfully
########## Application quiesce ##########
[Mon Jun 17 09:42:11 2013] INFO: Quiescing databases
[Mon Jun 17 09:42:11 2013] INFO: Quiescing database S5E
[Mon Jun 17 09:42:13 2013] INFO: Quiescing database S5E finished successfully
[Mon Jun 17 09:42:13 2013] INFO: Quiescing databases finished successfully
########## POST APPLICATION QUIESCE COMMANDS ##########
[Mon Jun 17 09:42:13 2013] INFO: No commands defined
########## POST APPLICATION QUIESCE COMMANDS FINISHED SUCCESSFULLY ##########
########## PRE COMMANDS ##########
########## PRE COMMANDS FINISHED SUCCESSFULLY ##########
[Mon Jun 17 09:42:13 2013] WARN: Snapshot's will not be deleted, if this is not desired please set NTAP_SNAPSHOT_NODELETE=N in config file
########## Detecting Data OnTap mode for segotx608 ##########
[Mon Jun 17 09:42:13 2013] INFO: Data OnTap 7 mode detected
[Mon Jun 17 09:42:13 2013] INFO: Data OnTap vFiler detected
########## Generating Info ASUP on segotx608 ##########
[Mon Jun 17 09:42:13 2013] INFO: ASUP create on segotx608 finished successfully
########## Gathering Information for segotx608:got608v005 ##########
[Mon Jun 17 09:42:13 2013] INFO: Performing Snapshot Inventory for got608v005 on segotx608
[Mon Jun 17 09:42:13 2013] INFO: Snapshot Inventory of got608v005 on segotx608 completed Successfully
########## Running Snapshot Rename on Primary segotx608 ##########
########## Creating snapshot(s) ##########
[Mon Jun 17 09:42:13 2013] INFO: NetApp Snap Creator Framework 3.6p1 detected that SnapDrive is not being used. File system consistency cannot be guaranteed for SAN/iSAN environments
########## Taking Snapshot on Primary segotx608:got608v005 ##########
[Mon Jun 17 09:42:13 2013] INFO: Creating Snapshot for got608v005 on segotx608
[Mon Jun 17 09:42:26 2013] INFO: Snapshot Create of r3s5e_db2-hourly_20130617094201 on segotx608:got608v005 Completed Successfully
########## PRE APPLICATION UNQUIESCE COMMANDS ##########
[Mon Jun 17 09:42:26 2013] INFO: No commands defined
########## PRE APPLICATION UNQUIESCE COMMANDS FINISHED SUCCESSFULLY ##########
########## Application unquiesce ##########
[Mon Jun 17 09:42:26 2013] INFO: Unquiescing databases
[Mon Jun 17 09:42:26 2013] INFO: Unquiescing database S5E
[Mon Jun 17 09:42:28 2013] INFO: Unquiescing database S5E finished successfully
[Mon Jun 17 09:42:28 2013] INFO: Unquiescing databases finished successfully
########## POST APPLICATION UNQUIESCE COMMANDS ##########
[Mon Jun 17 09:42:28 2013] INFO: No commands defined
########## POST APPLICATION UNQUIESCE COMMANDS FINISHED SUCCESSFULLY ##########
[Mon Jun 17 09:42:28 2013] INFO: ASUP create on segotx608 finished successfully
########## Checking Protection Manager dataset snapcreator_r3s5e_db2 ##########
[Mon Jun 17 09:42:30 2013] INFO: Checking if Protection Manager dataset snapcreator_r3s5e_db2 is conformant
[Mon Jun 17 09:42:31 2013] INFO: Protection Manager dataset snapcreator_r3s5e_db2 is conformant
[Mon Jun 17 09:42:31 2013] INFO: Protection Manager dataset snapcreator_r3s5e_db2 resource status normal
[Mon Jun 17 09:42:31 2013] INFO: Performing Protection Manager dataset verify for snapcreator_r3s5e_db2
[Mon Jun 17 09:42:31 2013] INFO: Protection Manager dataset changes not detected
[Mon Jun 17 09:42:32 2013] INFO: Protection Manager dataset verify for snapcreator_r3s5e_db2 completed successfully
[Mon Jun 17 09:42:32 2013] INFO: Performing Snapshot Inventory for got608v005 on segotx608
[Mon Jun 17 09:42:32 2013] INFO: Snapshot Inventory of got608v005 on segotx608 completed Successfully
########## Creating Protection Manager Backup Version for volume got608v005 dataset snapcreator_r3s5e_db2 ##########
[Mon Jun 17 09:42:32 2013] INFO: Finding all members associated with Protection Manager dataset snapcreator_r3s5e_db2
[Mon Jun 17 09:42:34 2013] INFO: All members of Protection Manager dataset snapcreator_r3s5e_db2 Successfully discovered
[Mon Jun 17 09:42:34 2013] INFO: Added member segotx608:/got608v005/segot2dbn1493 from dataset snapcreator_r3s5e_db2 to Protection Manager Backup Version
[Mon Jun 17 09:42:34 2013] INFO: Added member segotx608:/got608v005/segot2dbn1497 from dataset snapcreator_r3s5e_db2 to Protection Manager Backup Version
[Mon Jun 17 09:42:34 2013] INFO: Added member segotx608:/got608v005/segot2dbn1499 from dataset snapcreator_r3s5e_db2 to Protection Manager Backup Version
[Mon Jun 17 09:42:34 2013] INFO: Added member segotx608:/got608v005/segot2dbn1492 from dataset snapcreator_r3s5e_db2 to Protection Manager Backup Version
[Mon Jun 17 09:42:34 2013] INFO: Added member segotx608:/got608v005/segot2dbn1495 from dataset snapcreator_r3s5e_db2 to Protection Manager Backup Version
[Mon Jun 17 09:42:34 2013] INFO: Added member segotx608:/got608v005/segot2dbn1491 from dataset snapcreator_r3s5e_db2 to Protection Manager Backup Version
[Mon Jun 17 09:42:34 2013] INFO: Added member segotx608:/got608v005/segot2dbn1498 from dataset snapcreator_r3s5e_db2 to Protection Manager Backup Version
[Mon Jun 17 09:42:34 2013] INFO: Added member segotx608:/got608v005/segot2dbn1488 from dataset snapcreator_r3s5e_db2 to Protection Manager Backup Version
[Mon Jun 17 09:42:34 2013] INFO: Added member segotx608:/got608v005/segot2dbn1496 from dataset snapcreator_r3s5e_db2 to Protection Manager Backup Version
[Mon Jun 17 09:42:34 2013] INFO: Added member segotx608:/got608v005/segot2dbn1489 from dataset snapcreator_r3s5e_db2 to Protection Manager Backup Version
[Mon Jun 17 09:42:34 2013] INFO: Added member segotx608:/got608v005/segot2dbn1490 from dataset snapcreator_r3s5e_db2 to Protection Manager Backup Version
[Mon Jun 17 09:42:34 2013] INFO: Added member segotx608:/got608v005/segot2dbn1494 from dataset snapcreator_r3s5e_db2 to Protection Manager Backup Version
########## Running Protection Manager Backup Version Create for dataset snapcreator_r3s5e_db2 ##########
[Mon Jun 17 09:42:34 2013] INFO: Registering snapshot r3s5e_db2-hourly_20130617094201 with Protection Manager dataset snapcreator_r3s5e_db2
[Mon Jun 17 09:42:36 2013] INFO: Snapshot(s) for dataset snapcreator_r3s5e_db2 registered with Protection Manager successfully
########## POST DATA TRANSFER COMMANDS ##########
[Mon Jun 17 09:42:36 2013] INFO: No commands defined
########## POST DATA TRANSFER COMMANDS FINISHED SUCCESSFULLY ##########
########## Running Snapshot Delete on Primary segotx608 ##########
########## POST COMMANDS ##########
[Mon Jun 17 09:42:51 2013] INFO: No commands defined
########## POST COMMANDS FINISHED SUCCESSFULLY ##########
########## ARCHIVE COMMANDS ##########
########## ARCHIVE COMMANDS FINISHED SUCCESSFULLY ##########
########## NetApp Snap Creator Framework 3.6p1 finished successfully ##########
[Mon Jun 17 09:42:51 2013] INFO: INFO: Snap Creator finished successfully ( Action: snap )
