Data Protection
SDU AIX call NFS mount?
lsanchez
Hi,
customer have SDU with AIX. In the process of mount a SMO backup from a SV secondary, SDU trace logs show a nfs mount command like:
usr/sbin/mount -v nfs  stor01:/vol/SnapManager_20110629225423616_XXXX/XXX /sdu_tmp_readonly_test_mnt_point_1309402486
Filer don't have NFS licensed, and mount operation don't continue waiting this mount
to a aix level, it show:
sbin/helpers/nfsmnthelp M 0 stor01 vol/SnapManager_20110629225423616_XXXX/XXX /sdu_tmp_readonly_test_mnt_point_1309402486
Why this command is called if environment is only FC?
Host have one NFS mountpoint, but from other server.
Any way to disable this nfs mount?
Thanks
1 REPLY 1
arunacha
which version of SDU is being used...
If that is SDU 4.2 then it's a bug...
