Data Protection
SMO 3.1/3.2 and AIX PowerHA issues
bona
Hello,
IHAC who has SMO  (currently 3.1P1) on a PowerHA 6.1 (AIX 6.1) server.
All backups work perfectly.
The issue comes when you want to restore (or even just mount a snapshot).
I think I narrowed the problem with Snapdrive.
First , we used SDU 4.2P1 (and it didn't detect the righ version of HUK and PoxwerHA with sdconfcheck)
I tried to upgrade to Snapdrive for Unix 5.0 and it's better since it detects PowerHA.
We do still have the issues, and I think it may be a problem of detecting a supported version of PowerHA and HostOS.
As you see below, sdconfcheck doesn't show the Host OS information: we should have a line with "Detected Host OS ....."
sl1105 /opt/NetApp/snapdrive # bin/sdconfcheck check
Detected PowerPC Architecture
Detected IBM AIX OS
Detected FCP on AIX
Detected   AIX JFS File System
Detected   AIX JFS2 File System
Detected   AIX Native LVM
Detected   AIX Native MPIO
Detected   PowerHA6.1
Detected   FCP AIX Host Utilities 5.1
Detected   iSCSI AIX Host Utilities 5.1
Did not find any supported configurations by SDU Version 5.0
sl1105 /opt/NetApp/snapdrive # oslevel
6.1.0.0
When you do a backup mount or a restore in SMO, some snapdrive commands are run. I tried to run them outside of SMO and I get this:
/usr/sbin/snapdrive snap connect -fs /sl2105/oracle/OWPPPA/ora /opt/Ontap/smo/mnt/-sl2105-oracle-OWPPPA-ora-20120220113618248_0 -snapname n6240-2A:/vol/vol_2105_2_OWPPA_data:smo_owpppa_nohacmp_owpppa_f_h_1_4028fae9359a51af01359a51b2ca0001_0 -autorename -noreserve -prefixfv SnapManager_20120220113618326
connecting vgorajdeFRppd:
        LUN copy qt_2105_1_OWPPA_data01/2105_1_OWPPA_data01.lun_0 ... created
                 (original: n6240-1a:/vol/vol_2105_1_OWPPA_data/qt_2105_1_OWPPA_data01/2105_1_OWPPA_data01.lun)
        LUN copy qt_2105_1_OWPPA_data02/2105_1_OWPPA_data02.lun_0 ... created
                 (original: n6240-1a:/vol/vol_2105_1_OWPPA_data/qt_2105_1_OWPPA_data02/2105_1_OWPPA_data02.lun)
        mapping new lun(s) ... done
        discovering new lun(s) ... done
        Importing vgorajdeFRppd_0
        Cleaning up ...
deleting disk group vgorajdeFRppd_0
         - hostvol vgorajdeFRppd_0/lvoraowpp_0 ... deleted
         - dg vgorajdeFRppd_0 ... deleted
         - LUN n6240-1a:/vol/vol_2105_1_OWPPA_data/qt_2105_1_OWPPA_data01/2105_1_OWPPA_data01.lun_0 ... deleted
         - LUN n6240-1a:/vol/vol_2105_1_OWPPA_data/qt_2105_1_OWPPA_data02/2105_1_OWPPA_data02.lun_0 ... deleted
0001-034 Command error: mount failed: mount: /dev/lvoraowpp_0 on /opt/Ontap/smo/mnt/-sl2105-oracle-OWPPPA-ora-20120220113618248_0
Cannot mount guarded filesystem.
The filesystem is potentially mounted on another node.
Finally, another command shows there is a problem detecting that there is a PowerHA configuration:
sl2105 /opt/NetApp/snapdrive # snapdrive config check cluster
0002-028 Admin error: Host OS is not supported for -devicetype shared operations.
Is this happening because it doesn't detect Host OS ?
Anyone has an idea of what is wrong in configuration in AIX/PowerHA/PowerVM ?
Thank you
AB
1 ACCEPTED SOLUTION
bona
FYI,
the reason why it was not working is the customer configured the HACMP cluster in concurrent mode.
AB
1 REPLY 1
bona
FYI,
AB
