Data Protection
Snap Creator for Oracle 8 failed with return code [256] and message [stty: : Not a typewriter]
cheeleon
Hi All,
The Snap Creator for Oracle 8 was configured and running normal for the past months for customer, but now it return error as below;
########## Detecting Data ONTAP mode for 10.1.111.33 ##########
[2014-04-14 03:30:00,519] INFO: STORAGE-03031: System version details of [10.1.111.33].
[2014-04-14 03:30:00,519] INFO: STORAGE-03032: System version details of [10.1.111.33] finished successfully.
########## Agent validation ##########
[2014-04-14 03:30:00,784] INFO: Agent validation completed successfuly for agent 10.1.111.45:9090
########## Plugin validation ##########
[2014-04-14 03:30:00,784] INFO: Application not defined. Skipping Plugin validation task
[2014-04-14 03:30:00,784] INFO: Removing log p2cdmdb_oracle_database.debug.20140318033000.log
[2014-04-14 03:30:00,784] INFO: Removing log p2cdmdb_oracle_database.out.20140318033000.log
########## PRE APPLICATION QUIESCE COMMANDS ##########
[2014-04-14 03:30:00,784] INFO: Pre application quiesce commands are not defined
########## PRE APPLICATION QUIESCE COMMANDS FINISHED SUCCESSFULLY  ##########
[2014-04-14 03:30:00,784] INFO: Application not defined. Skipping Discovery task
[2014-04-14 03:30:00,784] INFO: Application not defined. Skipping validate volume task
########## Application Quiesce ##########
########## Application not defined. Skipping Quiesce task ##########
########## APPLICATION QUIESCE COMMANDS ##########
[2014-04-14 03:30:04,216] INFO: [10.1.111.45:9090 (4.0.0.1)] Executing Application quiesce command [/home/oracle/NetApp/oraback8.sh begin online ENTSP2] on 10.1.111.45
[2014-04-14 03:30:04,216] ERROR: [10.1.111.45:9090 (4.0.0.1)] Command [/home/oracle/NetApp/oraback8.sh begin online ENTSP2] failed with return code [256] and message [stty: : Not a typewriter
Not a terminal
Appreciate inputs from anyone who have any idea about this error messages, I have attached the oraback8.sh script for reference.
Thank You
1 REPLY 1
sivar
Hello,
Were you able to find a resolution?
Please refer these threads.
http://h30499.www3.hp.com/t5/Security/ssh-giving-stty-Not-a-typewriter-error/m-p/5094089#M17835
http://h30499.www3.hp.com/t5/System-Administration/Need-urgent-help-quot-stty-not-a-typewriter-message-in-Tidal/td-p/5420991#.U3rVRygguik
The error comes from ksh .profile settings as documented.
Please try the suggestions mentioned in the HP forum postings above.
Thanks,
Siva Ramanathan
