Data Protection
SnapCenter LUN Resize Issue After 5.0 Upgrade
TMADOCTHOMAS
Has anyone else encountered this? I just resized a LUN for the first time after upgrading SnapCenter to 5.0 and have found some oddball behavior. When I click in the text box to enter a number, it automatically increments the size by a random amount (and moves the slider forward automatically as well). I can get close to what I was going to do but it's an oddball result, like 51.67GB instead of 50GB as I intended. Basically, you are unable to type anything in the text box anymore. You have to accept the random increments (or drag the slider). I've tried it on several LUNs on several servers and they all do the same thing. Has anyone encountered/reported this? If not I'll open a case and try to get a bug submitted.
1 REPLY 1
DK-KMH
I can confirm it. The correct resize is not possible via GUI
