Data Protection
SnapManager for SQL Server PowerShell problem
penningtonkr
Hi,
Im trying to use the powershell scripts in order to interface with SMSQL on a 2 node cluster but have encountered the following problems when trying to use any of the commands:
PS C:\Program Files\NetApp\SnapManager for SQL Server> get-backup
Initializing [get-backup]
Connecting to server: [TMTESTSQLCLU01] [processing]
Failed to connect to the specified SQL Server.
Details: Error Code: 0xC0040804 Failed to connect to the specified SQL Server.
Failed to connect to Server: [TMTESTSQLCLU01]
get-backup : Failed to invoke the backup operation.
At line:1 char:10
+ get-backup <<<<
Scenario:
This is a two node active/passive SQL config as follows:
Cluster name: TMTESTCLUSRV
Instance name: TMTESTCLUSRV
Servername 1: TMTESTSQLCLU01
Servername 2: TMTESTSQLCLU02
Things I have checked:
  • I am running the commands via windows authentication and the account i am using has the sysadmin role in SQL and is a local administrator on the host
  • SnapManager backup and restore works throught the GUI using the same account so permissions look fine
  • I have used the command without -Server flag and get the same error
  • I have used the command with -Server and specified the nodes names and cluster name and all come back with the same error
  • The firewall is off for purposes of testing
Useful Information:
Windows Server 2003 SP2 Enterprise Edtion
SQL Server 2005 V9.0
SnapDrive 6.3 x64
SnapManager for SQL Server Version 5.1.0.676
PowerShell version 1.0.0.0
Can anyone see where I am going wrong with this?
1 ACCEPTED SOLUTION
draj
Here is the example given for get-backup cmdlet;
PS C:\Program Files\NetApp\SnapManager for SQL Server> get-help get-backup -exam
ples
NAME
    get-backup
SYNOPSIS
    This cmdlet enables you to list the backup sets of a particular database us
    ing the SnapManager SQL Server PowerShell command-line interface.
    EXAMPLE #1
    get-backup -svr 'VM-VS-1' -inst vm-vs-1 -d 'ds_test7'
      This example retrieves the backed up database list on a server instance o
    f the specified server.
You can probably try:
get-backup -svr 'TMTESTCLUSRV' -inst 'TMTESTCLUSRV'
4 REPLIES 4
draj
Hi,
Try giving the clustered instance name only (TMTESTCLUSRV) for -server and check if it works.
Thanks,
Deva
penningtonkr
Deva,
This is the output from the command pointed at the server cluster name:
PS C:\Program Files\NetApp\SnapManager for SQL Server> get-backup -server TMTESTCLUSRV
Connecting to server: [TMTESTCLUSRV] [processing]
Retrying to connect to SQL Server for validation [TMTESTSQLCLU01]
Failed to connect to Server: [TMTESTCLUSRV]
At line:1 char:11
+ get-backup  <<<< -server TMTESTCLUSRV
Any ideas?
draj
ples
NAME
    get-backup
SYNOPSIS
    EXAMPLE #1
penningtonkr
Deva,
Sorted you were spot on , thanks for you help:
PS C:\Program Files\NetApp\SnapManager for SQL Server> get-backup -svr 'TMTESTCL
Connecting to server: [TMTESTCLUSRV] [completed]
