Data Protection
how to remove running jobs not visible in Jobmonitor
SVOLLRAT1
Hi Everybody
We have a slight Problem with SnapCreator.
The Job-Database states that there are still two Jobs in running state that are no longer reachable in Job Monitor.
Any suggestion how to get rid of them?
BR
Stefan
6 REPLIES 6
sivar
Hello Stefan,
I haven't seen an instance where zombie jobs exist.
What kind of jobs (plugins) are these?
Does the 2 zombie jobs still persist, after a snap creator server restart?
What is the output of jobStatus command?
        ./snapcreator --server <IP> --port <Port> --user <User> --passwd <Passwd> --action jobStatus --verbose
Thanks,
Siva Ramanathan
SVOLLRAT1
Hello Siva
The Zombies or incorrect Entries are in the Database.
Processes on Agent-Side are already down.
I believe the issue was caused by restarting the scServer (every now and then the GUI is not reachable, still not fixed issue).
A Backup-Job was probably running at that time and the Database didn’t set the status properly after restart.
Output of the requested command is attached.
Freundliche Grüsse / Kind Regards
Stefan Vollrath
T-Systems Schweiz AG
Storage & Backup Operations
Stefan Vollrath
Storage Engineer
Murgenthalstrasse 12, CH-4901 Langenthal
+41 (0) 78 645 1076 (phone)
E-Mail: [email protected]
http://www.t-systems.ch<http://www.t-systems.ch/>
Notice: This transmittal and/or attachments may be privileged or confidential. If you are not the intended recipient, you are hereby notified that you have received this transmittal in error; any review, dissemination, or copying is strictly prohibited. If you received this transmittal in error, please notify us immediately by reply and immediately delete this message and all its attachments. Thank you.
Von: Siva Ramanathan
Gesendet: Donnerstag, 9. Januar 2014 16:26
An: Vollrath, Stefan
Betreff: - Re: how to remove running jobs not visible in Jobmonitor
<https://communities.netapp.com/index.jspa>
created by Siva Ramanathan<https://communities.netapp.com/people/sivar> in Snap Creator - View the full discussion<https://communities.netapp.com/message/123330#123330>
Hello Stefan,
Thanks,
Siva Ramanathan
Reply to this message by replying to this email -or- go to the message on NetApp Community<https://communities.netapp.com/message/123330#123330>
Start a new discussion in Snap Creator by email<mailto:discussions-community-products_and_solutions-databases_and_enterprise_apps-snapcreator@communities.netapp.com> or at NetApp Community<https://communities.netapp.com/choose-container.jspa?contentType=1&containerType=14&container=2481>
sivar
Stefan,
Sorry about the GUI issue you are referring.
Few of our customers have got around the GUI issue by increasing Java memory settings.
Also customers who have Snap Creator on Solaris boxes got around this issue by custom defining /tmp path for the Snap Creator GUI. (since it was found that /tmp was cleaned by Solaris automatically and ended up causing GUI issues for Snap Creator server).
If you have a support case on the GUI issue, please let me know. I will follow up with NetApp support.
I see only one job flagged as running.
Is this what you are trying to kill?
Are you able to kill it by the cancel button in the GUI? (if you increase job monitor size it may be visible)
19468  successful CH_TR               CH_TR_DOML_CHLNHUB01CH_TR_DOML_CHLNHUB01   Scheduledscadmin  backup     2013-12-30T07:18:29.205+01:00  2013-12-30T07:19:15.976+01:00
19469  running    CH_CT               CH_CT_SMVI_EV       CH_CT_SMVI_EV      Scheduledscadmin  backup     2013-12-30T07:30:00.053+01:00  -
19470  successful CH_TR               CH_TR_DOML_CHLNARC01CH_TR_DOML_CHLNARC01   Scheduledscadmin  backup     2013-12-30T08:18:29.306+01:00  2013-12-30T08:18:51.262+01:00
SVOLLRAT1
Hi Again
Job Monitor is at its max with 1000 Lines, so from GUI it is out of reach.
Any way to cancel via CLI?
Stefan Vollrath
Stefan Vollrath
Storage Engineer
Gesendet: Donnerstag, 9. Januar 2014 16:59
created by Siva Ramanathan<https://communities.netapp.com/people/sivar> in Snap Creator - View the full discussion<https://communities.netapp.com/message/123334#123334>
Stefan,
19468
successful
CH_TR
scadmin
backup
2013-12-30T07:18:29.20501:00 2013-12-30T07:19:15.97601:00
19469
running
CH_CT
CH_CT_SMVI_EV
CH_CT_SMVI_EV
Scheduled
scadmin
backup
19470
successful
CH_TR
scadmin
backup
2013-12-30T08:18:29.30601:00 2013-12-30T08:18:51.26201:00
Reply to this message by replying to this email -or- go to the message on NetApp Community<https://communities.netapp.com/message/123334#123334>
sivar
Unfortunately, there is no way to cancel from the CLI.
I am trying to see alternatives. (like our powershell cmdlet).
I will test this in the lab and let you know.
Is it causing your scheduled jobs to fail in anyway? (of the profile/config)
CH_CT           CH_CT_SMVI_EV
SVOLLRAT1
Hi
Other Jobs that are in failed Status usually had its reason on the Agent-Side f.E. failed Quiesce Script or on SMVI-Commandlet.
Colleague of mine just created a script that dumps the Job-DB and extracts long running jobs out of there and creates alerts based on that.
Due to these unreachable Jobs, already canceled but not mentioned that way in DB, we have daily Tickets that start to annoy us.
Stefan Vollrath
Stefan Vollrath
Storage Engineer
Gesendet: Donnerstag, 9. Januar 2014 17:28
created by Siva Ramanathan<https://communities.netapp.com/people/sivar> in Snap Creator - View the full discussion<https://communities.netapp.com/message/123336#123336>
CH_CT
CH_CT_SMVI_EV
Reply to this message by replying to this email -or- go to the message on NetApp Community<https://communities.netapp.com/message/123336#123336>
