EF & E-Series, SANtricity, and Related Plug-ins
disk replacing for Class 3650 Model 0834
Class3650
Hello,
I need to replace defective ST3600057SS LSI Part Number 42123-01 (MS03) for Class 3650 Model 0834 Storage, but there isn't an original part anymore. What can I do? Is there a solution?
Thanks.
1 REPLY 1
GidonMarcus
i believe the NetApp part number for the drive you are holding is X412 (it should say so on the metal case). you can search for this part online. or if you order a new one - look for X412B as the old part number is not available anymore (see https://kb.netapp.com/app/answers/answer_view/a_id/1000219/loc/en_US). it's important you get a NetApp branded drive. as it usually formatted with non-common block size, offset and come with special frimware.
Gidi
Gidi Marcus (Linkedin) - Storage and Microsoft technologies consultant - Hydro IT LTD - UK
