General Discussion
Automation
VishalKV
can anyone guide on how to build a ansible playbook for cluster health check including,
Hardware faults on Nodes, Shelfs, Disks, Ports, PSU, Fan, Motherboard, Connectivity and Configuration
Event logs - Find out critical errors and highlight the same on report, check on repeated warnings
2 REPLIES 2
mbeattie
Hi Vishal,
Ansible is not designed to be a reporting tool for Hardware faults on Nodes, Shelfs, Disks, Ports, PSU, Fan, Motherboard etc. IE you can't manage the configuration state for a hardware fault. You could run a series of commands to enumerate hardware environment issues. See:
https://docs.ansible.com/ansible/latest/modules/na_ontap_command_module.html#na-ontap-command-module
Active IQ is designed to monitor your storage clusters which will detects and alert on such hardware related events.
https://mysupport.netapp.com/products/p/activeiq_um.html
/Matt
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
VishalKV
Hi Matt,
Thank you for the response,
you are right, so you mean to say I should run set of ad-hoc commands to get the status and produce a report using those outputs.
Actually I am spending lot of time running health check commands on daily basis, which I need to automate, so I thought there can be some playbooks in ansible which can automate.
And AcitveIQ is dependent on asup messages, which is not showing the present status/alerts of the system, my plan is to run this script twice a day and get the report generated.
any alternative like shell script can get this done I think, do you have any idea on the same?
/Vishal
